Cleaning a MAF
Cleaning a MAF
I pulled the truck out of the garage the other morning and it had trouble getting going. I had to lightly pump the throttle to get it started. Hmmm, somethings amiss! Feels like it's hesitating a bit a highway speeds, then, at every stop, I needed to lightly pump the throttle to pull out. Then the check engine light comes up. Without a way to pull the CEL code (I've now ordered the BR3) I took a guess at the MAF. Pepboys and Advanced Auto have no sensor safe cleaner "just use throttle body cleaner!" No thanks...I'll keep looking.
I pulled the MAF out expecting to see it covered with gunk. But no, it looked pretty clean. Assuming anything under the hood is designed to take a little moisture, I mixed up some regular Dawn dishwashing soap and water. Put it in a spray bottle and LIGHTLY misted the MAF. I then cut the head of a Qtip down the middle length wise and GENTLY cleaned the bulb and the area all around it. It was not real dirty, there was very little residue on the Qtip. I put it all back together and that was it. CEL is out, runs like a champ. In fact, it seems to run smoother...go figure! BTW, I have the standard toyota air filter installed. Moral to the story, that MAF does not need to be real dirty to cause problems.
YMMV
YMMV
I bet the CE light is a misfire code. How long have you had the SC on? Did you switch to the colder plugs? How many miles do you have?
I believe we have a write-up on cleaning the MAF.
Good Luck
:bounce2:
Good Luck
:bounce2:
MAF Cleaning Links
Originally Posted by broknlgs24
where's the write-up on cleaning the MAF? i checked and could not find one.
thanks!
thanks!
http://www.4x4wire.com/toyota/mainte...tenancep5.html
http://www.4x4wire.com/toyota/4Runner/tech/BR-3/
B
Koolbananass
08-12-2015 01:59 AM
