automatic transmission flush?
I have 2002 4wd 4runner. I going to attempt to flush the transmission. I know that the system capacity is around 15 qts. I drained 5 qts out of the pan. I also changed the filter and refilled the pan with 5 qts. Now i am at the point of actually flushing the system. Now, do i need 10 more qts. since i have already added 5 qts., or do i need to flush with 15 qts? Does the fluid i replaced after the filter change mix with the old fluid? Also, does the return line come out of the bottom of the radiator on the drivers side? :pat:
blackdog, on my 2001 the return from the cooler was the driver's side. To be sure, the steel tube that exits the A/T nearest the front, is the output, follow that through your system.
Follow the steps here: http://www.amsoil.com/faqs/faq8.htm to flush the A/T. I used a 5 gallon bucket and made up a measuring stick to measure how much pumped out versus poured in. I had to stop twice to catch up.
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
BeMiceElf
10-10-2015 09:40 PM
