| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3VZE Water Pump - Need Help w/Install
__________________
1991 Truck 2WD 22RE 5SPD |
#2 (permalink) |
That looks like what needs to be done. I didn't really find it very hard to do once I got going. Probably the most difficult thing was getting the bolt off the crank pulley. I needed an impact wrench for that.
Definitely replace the upper idler pulley if there is any sign of roughness in the bearings, or even better replace it anyway. Also put a new timing belt on. No point on doing the work again when that needs replaced. I didn't do the seals, but they are cheap to buy so if there is any sign of leakage I would replace them. Good luck. |
#3 (permalink) |
Eric,
Thanks for the input. Should I remove the radiator? Anything else that might make life easier down the road? Thanks again for your thoughts.
__________________
#4 (permalink) |
Yes, remove the rad, and the grill. It's a lot easier than scraping your knuckles on the fins.
#5 (permalink) |
Sounds like a plan, thanks!
__________________
#6 (permalink) |
I just got done replacing my water pump, timing belt, and upper idler pulley a few days ago. I was a little worried about it but once I torn into it, it wasn't too bad at all. The crank bolt wasn't all that bad either. I would throw on some new belts while your taking things out, put all new on mine, and it seemed to quiet it down a bit. Can't really think of anything else to help you out except getting the radiator out of the way, and keeping track of how everything came apart, pretty straight forward. I didn't remove my grill, shouldn't have to. There is quite a bit of info on here if you search. Good luck, have fun.
#7 (permalink) | |
Quote:
Thanks, and yea right! Thanks for the positive feedback. Hopefully I'll get to tear into it tonight. Thanks Eric and Arsrmk for your comments.
__________________
#8 (permalink) |
I replaced mine a couple of years back. Get yourself some ziplock bags and a permanent marker. When you take a component off, put all the bolts, nuts and washers in a bag and mark where it came from. Plan on replacing both idlers...it's easier now than later. Take your time and be meticulous about lining up your timing marks...toyota timing belts work best...You'll love it when it fires up the first time.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home. '95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck. |
#9 (permalink) |
Okay, so I am taking my sweet time with this one. It turns out the water pump is fine (and resonably new, verified by reciepe from previous owner) so I'm going to leave it alone. I have it all tore apart with one exception. I cannot get the crank pulley bolt out!
I've used some of the baddest Snap-On 1/2 drive impacts and they don't even phase it. It's not LH thread is it?Anyway, the problem is the carrier bracket for the cooling fan...it puked the bearings that support the cooling fan shaft and the idler pulleys for the PS and alternator. Since I have it apart this far I'm thinking I'll go the Taurus electric fan route. The bearings took pieces out of the timing belt so I'm going to still need to replace that. I'm still waiting on some of the parts but I need to get this thing apart. Thanks for the posts, Andrew
__________________
#10 (permalink) | |
Quote:
Good luck, ( and wear ear plugs) |
#11 (permalink) | ||
Quote:
Quote:
WOW, this probably isn't the recommend procedure, is it? If you use this method, are you still able to turn the motor over to line the timing marks up? Also, the earplugs...are they required to mask the sound of breaking parts?
__________________
1991 Truck 2WD 22RE 5SPD Last edited by Faded; 02-16-2004 at 10:13 AM. |
#12 (permalink) | |
Quote:
#13 (permalink) |
I just used a 2 ft breaker bar and had my girlfriend hold the pulley with a 2 ft long chain wrench with about a 2 ft pipe on the end. It was tight but came loose with a good hard pull. I would say go this route, just get a longer pipe if it won't break loose.
#14 (permalink) |
Flame suit on....
I have removed several tight-as-hell crank pulley belts by using a 1/2" breaker bar and quickly bumping the starter, thus whacking the breaker bar on the ground or frame and breaking it loose. (Have someone verify the direction of rotation when the starter is bumped) Most recently, I did it for my neighbor who was trying to get that bolt loose on his Saturn, it worked, but took like 5 bumps to get it. Most of all, if you try this, BE CAREFUL. But, it does work. I used to try the largest impact wrench the military auto-hobby shop had, with the air pressure cranked up, and it never worked. Flame suit off.... Another note: when done, get the crankshaft bolt as tight as possible, because they've been known to loosen up and chew up the keyway on the crankshaft which means big $$. Another thing I learned to do is when the new timing belt is installed, go ahead and manually rotate the engine through a couple complete revolutions (with a ratchet on the crank pulley) to ensure that the timing marks are lined up correctly.
__________________
Rob 95 Runner SR5 V6 5sp ATK engine, K&N FIPK, NWOR headers, high-flow cat w/2.25" Dynomax Super Turbo, 15X8 Centerlines, Michelin 32X11.5, Aisin hubs, Factory Brush bar, PP Rear Springs, KYB Monomax shocks, Westin Nerfs, Bushwackers, Weatherflectors, OME Steering Stabilizer, Marlin Short Shifter, White gauges, Taurus fan, MR2 100 Amp alternator, stereo&alarm w/DEI 530T 4:88's w/Supra LSD Front and Rear |
#15 (permalink) |
I used that technique with my old Corolla when I replaced the belt. Yes it does work. It can cost you some teeth on the flywheel if it doesn't though. It's a last resort. Gotta love that DC motor torque.
__________________
#16 (permalink) |
Thank you for the replies. I actually tried it last night but broke two sockets in the process. The were semi-cheap spares that I had so I didn't mind, but now I know I'll need a quality socket. I should have used a good one in the first place, but figured 'what the hell'.
I'll be sure to give it a couple of rotations to make sure everything lines up correctly. That was on the list of things 'to do', but thank you for the reminder. I also am thinking about putting a little twist on the fan/weight removal idea, I'd be interested in anyones comments. I talked with Gadget a while back about a guy he knew that removed the idler pulleys on the fan shaft on his 5VZE. I was looking at mine last night and I think I'm going to try the same. There is only one offending stud that is used to fasten the fan bracket on. Since the fan bracket is basically shot and will now assume the roll of being only a timing belt guard I'm thinking I'll remove the stud and then machining the face off of the fan support bracket to clear the P/S and alternator belts. This along with some new, properly sized belts should help eliminate even more weight (not really that much) and parasitic drag by having the two belts go directly from the crank pulleys to thier repected accesories. Wadda think? Thanks again for the helpful comments. -Andrew
__________________
#17 (permalink) |
I'm not sure if I understand what you're talking about, but is it you want to go to an electric fan, then bypass the existing fan pulley? I would not recommend that, because that fan pulley is what rotates the impeller for the water pump, and it'll probably get a little warm...if I didn't understand, let me know more.
__________________
#18 (permalink) | |
Quote:
__________________
#19 (permalink) |
BTW, I just read your mods....I'm interested in the 100A MR2 alternator as well, but I'm wondering what you did for the lower bracket?? The write-up I saw the lower bracket looked kind of...um...chinzy.
__________________
#20 (permalink) |
I have pics, but no way to host them so I can link them to the post. Anyone know who/where I can get some help with this?
Also, do any of you know if our crank pulleys have a built in harmonic balancer? I have found a company that is willing to make lighter weight underdrive pulleys (so far crank and possibly power steering and/or others...still ironing out the details) but I've heard bad things about the lighter weight pulley's replacing harmonic balancer type OE crank pulleys. If you have any info I'd appreciate it. Thanks, Andrew
__________________
#21 (permalink) |
UPDATE:
Well, I've decided that it is very doable to eliminate the two extra idler pulleys that mount behind the cooling fan. I'll be gathering up shorter power steering and alternator belts and making the necessary modifications to fit them. My timing belt finally showed up, now if I can just get my electric fan here.
__________________
#22 (permalink) |
Hey,
Did you get the crank bolt out? It's a real bugger. I built a little tool to get my bolt out. Just get a 4"x 1/8" x about 3' piece of steal. Use your power steering pulley as a template and drill 4 screw holes (where it screws into your crank pulley) into the end of your piece of steal. Then drill a big hole (like 2"1/4 or something) in the center of these 4 holes. Then screw your piece of steal into the crank pulley where the power steering pulley usually goes. Let the rest of the piece of steal to either rest under the frame rail or you can have it coming up and use it as a handle to keep your crank from turning. You can use a socket to get to the crank bolt through the big hole you just drilled. By doing this, you don't have to worry about breaking any teeth on your flywheel. It worked great for me! After you get your timing belt back on, rotate the crank 2 times as mentioned in the previous posts. Check you timing marks again. It took me about 10 tries to get mine right. Might be a good idea to check your ignition timing when your all done too. Anyhow, sorry for going so long. Have fun. ![]() DH6twinotter
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. |
#23 (permalink) |
DH6twinotter,
Thank you for the comments. Yes, I did get the pulley off. I socket and a breaker bar along with cranking the engine over did the trick. I'm waiting on my fan right now, I have the timing belt but haven't put it on. I'm dragging my feet again. I've recently had death in family over the weekend so it might be a while yet. Thanks again, Andrew P.S. Great Idea on the tool! I'll probably go that route next time and for future maintainance. Thanks!
__________________
#24 (permalink) |
Glad to see you got the crank bolt off using the starter method, scary, but it works. I didn't know the timing belt turned the water pump, as I haven't changed my timing belt on this yet (at least another 47K before 60K on the belt). The lower bracket came with the alternator when I bought it. Like this link says, he bought another factory bracket, and had it welded to extend the length of it. The bracket felt very sturdy to me, and it's been working great since I installed it.
That is a good idea on the tool (it'd make it easier to properly torque the bolt back on). BTW, where's the pic? http://www.off-road.com/toyota/tech/100alt/index.html
__________________
#25 (permalink) |
Yea, that's the article I was looking at on the alternator. I've finally found a place to host my pics, but now i'm buried with work. Might not be until Monday, sorry. I thought I'd better post back so you didn't think I was being rude or ignoring you. I'm leaving town for the weekend, but I'll get those pics up Monday or so.
Thanks, Andrew
__________________
| Tags |
| 5vze, 9463, bolt, crankshaft, napa25 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2nd Gen 3VZE engine: R U thinking of doing timing belt/water pump? My observations | Forerunner | 86-95 Trucks & 4Runners | 35 | 10-07-2009 10:04 PM |
| leak from water pump gasket ,water pump | dcmbsc | 86-95 Trucks & 4Runners | 10 | 08-06-2007 08:46 AM |
| 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement | Lucky_13 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 11-17-2005 09:37 AM |
| 93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement | Lucky_13 | Maintenance & Repair Archives | 1 | 11-16-2005 04:26 PM |
| Timing Belt and Water Pump Install?? | ravencr | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 09-22-2004 11:38 AM |
