22re timing chain/set timing/rtv/headremoval - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-14-2005, 05:33 PM   #1 (permalink)
Just orderd timing chain, cam, headgasket, and head bolts for my 93' w/22re. To save time taking stuff apart, im thinking of something...could i just pull the head off with all of the intake components still attached? This is a DD truck and needs to be finished over a weekeends time. Another question is, anyone have pics of how to jumper the dist. to set the timing. One more, what kind of RTV sealent do i need to get since i wont be pulling the oil pan, instead i will be taking off only the front 2 and need to reseal where the covers fit together...
thanks
__________________
1993 Toyota Pickup 4x4
Current Mods--All Pro E-Brake, All Pro Rear Disk Conversion
brendonv is offline
Old 09-14-2005, 06:34 PM   #2 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
http://www.4crawler.com/4x4/CheapTri...ds/index.shtml
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
jimbo74 is offline
Old 09-14-2005, 07:36 PM   #3 (permalink)
RED 85's Avatar
I wouldn't just because of the risk of cracking something, and the extra time saved is not that much. You could take the intake off but leave the hoses and wires attache so you don't have to do them over. wich is the most time consuming part of the intake.
Just my 2 cents.
B
__________________
Brandi
You heard of the boy named Sue, Well I'm a man named Brandi!
'85 extra cab pick-up, Up on blocks waiting for time and money.
'85 4-runner with 3" lift, 33's, 4.88's, rear ARB (still trying to get air to it), Downey intake with K&N filter, some type of header, Camo Int.
RED 85 is offline
Old 09-19-2005, 11:59 PM   #4 (permalink)
Send a message via AIM to miket223 Send a message via Yahoo to miket223
Yes, you can leave the intake manifold and exhaust both installed on the head when you lift it away from the block. Naturally, be very careful to get those wires unhooked. The knock sensor and oil sending unit are below the intake manifold. The fuel filter is also down there and needs one end disconnected if you leave it attached to the block.
miket223 is offline
Old 09-20-2005, 07:18 AM   #5 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
yes it can be done (I have done it that way). Like Mike said make sure you get things disconnected before pulling, I broke the knock sensor when I did mine ($110 mistake)I used the "Toyota Black" gasket. Here is a tip don't drain your oil until everthing is put back together, that way any junk that gets into the pan drains out with it. Are you having the head checked at a machine shop while apart? If so don't forget about the long allen head bolt going thru the water jacket holding the intake to the head.
here is a link for the FSM and has all of the info you need for anything on your truck..http://personal.utulsa.edu/~nathan-b...fsm/index.html. Including the diagnostics connector for checking timing and head removal.
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Tags
1993, 22, 22r, 22re, chain, set, setting, standard, time, timeing, timimg, timing, tinimg, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re help (just did the timing chain) Boosted Chemist 95.5-2004 Tacomas & 96-2002 4Runners 12 01-04-2008 03:21 AM
Timing Chain 22re cweich 86-95 Trucks & 4Runners 1 12-22-2006 05:12 PM
22re timing chain 4RunnerLVR86 86-95 Trucks & 4Runners 5 10-07-2006 11:15 AM
Timing Chain, 22RE AH64ID 86-95 Trucks & 4Runners 26 04-17-2006 01:27 PM
22re timing chain Brendan 95.5-2004 Tacomas & 96-2002 4Runners 2 04-25-2004 10:03 AM
2009 InternetBrands, Inc.
