YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-29-2008, 06:15 PM   #1 (permalink)
Using a 1986 EFI System in 1985 CARB
I just bought a brand new engine 22RE EFI, I took everything EFI from a 1986 toyota pickup 4wd manual and swaped it into my 1985 toyota p/u 4wd. I can't find a 1985 EFI system or i would of swaped it in. If i use a 1986 Wiring harness will i run into any problems?
__________________
This is going to get EXPENSIVE!
dezrik is offline
Sponsored Links
To remove this ad, register today!
Old 01-29-2008, 10:07 PM   #2 (permalink)
rockdawg84's Avatar
Here you go. Almost everything you will want to know.
http://www.pirate4x4.com/forum/showthread.php?t=316661
good luck.
__________________
84 Runner streched and pounded but still crawlin
95 Runner about to be a fire Breather. I hope
rockdawg84 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
efi out/carb in gradalljohnny Newbie Tech Section 31 12-06-2007 04:29 PM
82, carb or EFI is the question Thundermaxx Newbie Tech Section 4 07-12-2006 12:10 PM
Changing from Carb to EFI rmpruitt 95.5-2004 Tacomas & 96-2002 4Runners 24 10-02-2005 10:43 AM
EFI to carb and back again? yotanso-o 95.5-2004 Tacomas & 96-2002 4Runners 1 05-01-2005 06:56 PM
Carb & EFI ?? The Nak 95.5-2004 Tacomas & 96-2002 4Runners 22 04-27-2005 05:23 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
