Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
4.3 Vortec
I Know this question gets asked a lot, and I'm new too the site but I'm getting ready or at least starting too get ready too swap a 4.3 liter in too get rid of the tired out 3.0 Liter. So here is my question, how big of a pain in the butt is it too do really? I know advance adapters and downey's make kit's too help with the conversion, I only Have a 2 inch body lift right now with that said, I was thinking of doing the engine swap and then drive it for now then when I can find axles do the SAS, or should I do the SAS then the engine? Any advice will be great, thanks guy's
| Sponsored Links |
#2 (permalink) |
Joker, these engine swaps have a way of getting real expensive. The adapters themselves can be $400-500. Then there is all the little things that add up. So I'd say, if it's running fine now, or maybe needs top end work, keep it and do the SAS.
__________________
Fires, Friends, and Books Decree Wisdom, Strength, and Controversy. To believe with certainty, one must begin doubting. |
#3 (permalink) |
swap
I just got done doing my swap with a '96 4.3 esmfi and 4l60e trans in a '95 truck and here is what it cost to get everything to complete and make road worthy
1 x-fercase adapter with vss sensor 1 6bolt to 4bolt adapter 1 wiring harness from fuel injection speaciltys 1 new v-6 toyota radiator 1 motor mount set 1 fuel line and filter 1 pcm reprogramming 1 new a/c condensor, dryer and hoses and recharge 1 throttle cable 1 output shaft in trans and service at a tranny shop $65.00 1 fan clutch elimanator kit 1 shifter b&m service parts for engine plugs, wires etc. all swap parts mostly came from downey 1 exhaust system 2 1/2" single $200.00 COST $2387.00 SHIPPING $101.34 ENGINE AND TRANS FROM A '96 S-10 BLAZER WITH 64000 MILES $750.00 SAS FROM TRAILGEAR FRONT AND REAR $$1500.00 2" BODY LIFT $89.00 drive shaft lengthen and shorting $250.00 BUT I am glad i have done it i have 4.88 gears 36" tires and the mpg so far with 2 tanks have been 19.4 miles per gal. with a little hotdogging here and there |
#4 (permalink) |
Do the suspension then motor.
As for how hard? Its not and its worth it Do it
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
#5 (permalink) | ||
Quote:
Quote:
As far as the swap itself...it's not hard at all. I would recommend doing the SAS first, then the motor. What kind of tranny are you planning on using, BTW?
__________________
Pure Bliss |
#6 (permalink) |
go for the power first to carrie the weight of the new axles and bigger tires good luck
__________________
bigblockyota 884runner chevy 454 fuelinjected fullsize chevy dana 60 axles 14bolt rear 5.38grs spools frt,rrear 4wheel disc conversion tur400 trns 203 dbler 205 tranfer aprox 8-10 inch lift 37inch tslboogers 3inch magnaflow exhaust msd ingn aluminum rad ,flex fan 56 , inch spring conversion w8000lbcomp winch and bumper and just added a full hydraulic psc steering kit |
#7 (permalink) |
Dang. Wish mine cost $2 -3.5k! By the time all is said and done, I will have $7.5k into my swap, and only $1900 of that is labor! wtf! I knew I should have just got a F*kin LCEng. motor that is already built.
BTW, im STILL waiting on my #WE$R%T^Y&U 4runner back for . FYI - Do not recommend these guys - I gave them my 4runner Feb. 4th - -- notice the date? its June 23rd!! >:O The whoel reason I brought it to them was to get it done in the two weeks they quoted me. A lawyer is sounding very good right about now....
__________________
'91 Runner: SAS, 4in AP front springs; Hi-steer, 4.88s, 5150 Bilstiens, 6in AP rear leaf spring conversion, Lockrite, 35x12.5x15 KM's, Procomp steelies, Warn front bumper. Now in process of: 4.3L, 4L60E, T-case Ebrake Little farther future: Dual Cases, Rear Disc, Arb lockers, Chop top & Exo. Last edited by 91RockRunner : 06-25-2008 at 09:58 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| I need a vortec 4.3 v6 | cumminsman911 | Items Wanted | 1 | 05-18-2008 08:48 AM |
| 4.3L Vortec TBI Atlanta | zman2day | Engine/Tranny/Parts | 0 | 01-03-2008 04:37 PM |
| 4.3 vortec swap questions | vwfastg60 | 84-85 Trucks & 4Runners | 2 | 10-21-2006 05:20 PM |
| Vortec V6 or LS1 V8 | MonsterMaxx | 86-95 Trucks & 4Runners | 21 | 09-27-2006 10:46 PM |
