1988 3.0 3vze to a 19393 3.0 3vze Help ID lines
1988 3.0 3vze TO 1993 3.0 3vze Help ID lines
I know this might seem very easy but I have some major issues I’ve been wrestling for a few days. I don’t seem to remember where these hoses or sensors connects to. I need major help. I’ve post in the IFS tech section but got no where..
This pic is the 2 portion of the intake manifold. I have no idea where these vacuum lines go to. The others I was able to find on the FSM…
I have 2 hose about a 14 inches in length that runs to the bottom of the power steering unit, also a little confuse where it goes? Seems to be a vacuum sensor?
[B]This sensor is located by the Water By Pass Outlet, located behind the manifold between both LH & RH heads, I don’t know where this belongs to. I do have a Blue wire located no more than 4 inches from it that is cut, but with no male connector. PIC = sensor in question is left arrow…[/B]
Backcountry411
07-24-2015 08:06 AM
88yodabasket
07-13-2015 01:32 PM
