Scuba's 99 Single Cab SAS.. 5 Years in the Making
Old 03-17-2014, 06:16 PM
scuba's Avatar
Who you order it through by chance??
The hanger kit? Direct through Front Range.
I'm not aware of any companies that are dealers for them.
Old 03-17-2014, 06:34 PM
kornhuskerwizard's Avatar
Sorry...the FROR threw me off , as ive never ordered through them before. I do not know who my hangar kits from i beleive trail gear or all pro. I bought it off clist but its new with high steer and the greasable 1.5 shackles. Hope your build goes well.
Old 03-17-2014, 06:42 PM
scuba's Avatar
I might be able to help ID your stuff. Got any pictures of it in your build thread?
Old 03-18-2014, 03:38 AM
Theres a pic of it all on my 89 4runner build...Ill repost a pic after work of all of it.
Old 03-18-2014, 06:28 AM
  #25
scuba's Avatar
Great, Summit canceled my order for the steering box because Cardone doesn't have one in stock.
We'll see what I can come up with. Either way, I'm stuck for 3-5 days as summit holds my money.
Old 03-18-2014, 06:29 PM
  #26
Thats no good!!Im also waiting for my allpro springs that are on backorder...
Old 03-18-2014, 06:40 PM
  #27
scuba's Avatar
I contacted summit and they ended up putting my box on back order.
If it takes longer than a couple weeks I'll go elsewhere. Probably Napa.
Got my steering shaft kit from TG today. Everything looks good.
Also got the front axle parts from my dad today. The knuckles and spindles need to be taken to the car wash, I might do that tomorrow.
Today I got to borrow a friends press so I could put my Marlin 25 MM pin kit and arms together.
The difference in size vs. stock. These are BEEF!
Special thanks, again, to Tom (Monkeyproof) for these FREE Marlin Crawler arms. Can't thank you enough!
Old 03-18-2014, 07:51 PM
  #28
snobdds's Avatar
Glad to see you finally embarking on this adventure. However, another advocate of IFS is now turned to the dark side. I hope you don't make things too easy for yourself.
Old 03-18-2014, 08:07 PM
  #29
scuba's Avatar
Don't worry, I won't. I'm sure I'll continue to try and take on trails I have no business on.
Old 03-19-2014, 03:19 AM
  #30
Hmmmmm.Those pins are massive compared to stock!!Ill have to check mine out tonight and compare.
Old 03-19-2014, 11:26 AM
  #31
scuba's Avatar
Got my knuckles and spindles washed up today. Need more cleaning. There's 10 years of caked on grease on the knuckles. I'll probably soak them in something overnight soon.
Got the axles out of the tundra rear. Tried getting the 3rd out but the fipg has it very stuck. Will try again soon.
Got my brake brackets painted. Color matched them to the truck. Didn't feel like buying black paint and I had this stuff laying around.
That's all for today. Really can't do much else with the front axle until its under the truck.
Old 03-19-2014, 05:56 PM
  #32
BigBluePile's Avatar
Sweet
Old 03-24-2014, 01:10 PM
  #33
scuba's Avatar
Went over to the storage unit today to drop off my steering shaft u-joint, my new manual hubs, and a set of free bilstein 12's I got from a friend. Also wanted to get the knuckles, spindles, and these manual hubs soaking in some purple power to get them a bit more clean.
The FROR hanger kit should be shipping this week.
I'll be buying the correct steering box in the next day or two after summit finally refunds my money.
After that, I'll have under $1000 of remaining parts that I need before I can start cutting.
I removed the AP shock hoops from my list. They probably won't work due to the location that my steering box will have to be in. I'll just grab some cheap tube and bend up my own.
Also, considering I found a power steering fluid that will work in both my stock power steering pump as well as the ford box, I won't be needing the PSC pump kit.
I just need to source the proper conversion lines.
Couple crappy pics for proof.
Will update more when I have more parts.
Old 03-24-2014, 06:00 PM
  #34
snobdds's Avatar
At least I know I'm not the only one who seems to do nothing but wait on parts. Progress is progress through and might as well have everything ready to go when go time comes...
Looks like fun though, keep it up.
I like that your still rocking the "pics or didn't happen" from way back.
Old 03-24-2014, 06:11 PM
  #35
Free bilsteins...Nice.
Old 03-24-2014, 06:46 PM
  #36
Roark's Avatar
Old 03-24-2014, 06:47 PM
  #37
Roark's Avatar
Looks good. Keep up the good work
Old 03-27-2014, 12:49 PM
  #38
scuba's Avatar
Finally fully cleaned up the knuckles, spindles, and manual hubs.
Started prepping to get the knuckle bearing preload set up.
The Marlin Crawler 25MM lower caps have their own hardware, so I pulled those studs out of the knuckles. No biggie.
Lots of parts coming in tomorrow. Still waiting on a refund from summit to start ordering more parts.
Old 03-27-2014, 01:49 PM
  #39
Fossilized
Staff
dropzone's Avatar
Smart man with the strapd to keep the axle in place
Old 03-27-2014, 02:10 PM
  #40
scuba's Avatar
No other way of doing it IMO. The damn thing just won't stay still.
Quick Reply: Scuba's 99 Single Cab SAS.. 5 Years in the Making
