SAS clunk.....clunk.....bang....
Old 12-24-2013, 06:00 PM
BigBluePile's Avatar
I'd like to think the bushings are good or else they wore out after less than 6 months.
Well, I'll take a look at the alternator area tomorrow and see. Thanks!
Old 12-24-2013, 07:21 PM
rattlewagon's Avatar
I think we need a video of this sound. My first thought was the leaf springs or shackle bushings.
You sure it not just mag light rolling around under the drivers seat?
Old 12-24-2013, 07:26 PM
I'll need a go-pro for the video but I can possibry do that this weekend.
I wish it was a maglight!!
Old 12-25-2013, 04:29 AM
88_Red_Runner's Avatar
Did you make sure and weld the frame tubes in straight and take a cross measurement?
Not just front to back. If they are in crooked the bushings will wear very fast. Good luck BBP.
Old 12-25-2013, 02:56 PM
  #25
Nah. Didn't have anything to run across tube to tube. I'll have to check the bushings.
Old 01-07-2014, 03:38 PM
  #26
Soooooooo....I went thru and found all my body mounts loose.....!
Tightened them up and guess what???
Nope. Still have noise. Lol. Also, because I've taken a few springs out of each pack I went ahead and made some Teflon blocks to fill in the gaps and keep some tension on the leafs. Still have noise.
I can feel it thru the floor boards at times as well. Also, there's no interference between the alternator and steering shaft.
Old 01-08-2014, 05:05 PM
  #27
Hey BBP, I was thinking about doing different engine mounts in my 4Runner and it made me think about your problem. Do you have a torn engine mount? Or could it possibly be a torn T-case mount? I would check those to see as well. Lockers, big tires, and low gears put strain on those old rubber mounts. Hope this helps and good luck again.
Old 01-08-2014, 05:20 PM
  #28
I will look all the mounts over. At this point anything and everything is suspect! Lol. I have a rockstomper poly mount on the drivers side and a brand new OEM mount on the passenger side. My gear drive tcase has the bigger V6 mount and I bought brand new 10 years ago
Thank you!
Old 02-12-2014, 07:24 PM
  #29
Think I figured it out. As most suggested it was just spring noise. So, with a can of WD-40 I hosed the spring packs down and viola! no more noises. So, we will see if the noise comes back after some time.
Old 02-13-2014, 09:30 AM
  #30
rustED's Avatar
Glad you got it figured out! My 86' 4 runner SAS just started doing the same thing this winter after dd it for a year and a half with no noises. It makes that thunk sound when turning either direction, sometimes I could feel it through the floor boards. I'm running a hybrid RUF pack though, probably doesn't help that I still haven't installed any leaf spring clamps yet, lol. Anyway glad you were able to figure it, I'll have to give that a try!
Old 02-13-2014, 04:47 PM
  #31
It's starting to make noise again, I think the wd40 is wearing off
Old 02-13-2014, 05:21 PM
  #32
Fossilized
Staff
dropzone's Avatar
teflon spring pads
http://www.carid.com/universal-suspe...FQ-DfgodGUsA_Q
Old 02-14-2014, 04:08 PM
  #33
^^^yuppers
Old 03-06-2014, 09:10 AM
  #34
taconasty's Avatar
I had a similar noise after installing my trail gear kit and hysteer. I figured out it was the steering stabilizer would rotate my steering arm and was making the tre clunk. Caused premature wear, the stabilizer is gone now. See if you can rotate the steering arm easily.
Old 03-06-2014, 07:09 PM
  #35
I'm not very happy with my steering stabilizer either. It groans obnoxiously on occasion. Piece of crap. I cannot "easily" rotate the steering arm. It takes some effort. I'll keep an eye on the tre's though, thanks!!
Old 04-17-2014, 11:59 AM
  #36
hollymcmen's Avatar
wheel bearing
Old 04-17-2014, 02:19 PM
  #37
Fossilized
Staff
dropzone's Avatar
Originally Posted by hollymcmen
wheel bearing
Entire front end was rebuilt prior to install.
Why would it be will bearings when the sound went away after WD40 sprayed on the springs helped?
Old 04-17-2014, 04:35 PM
  #38
My springs are clangy too. Ill have to try the wd40 trick.
Old 04-18-2014, 12:21 PM
  #39
wheel bearing
Sure wasn't.....
Muffler bearing was a little loosey
Indeed. It lasts a little while and then you'll have to spray again. Grease would be better I suppose. It's a good way to troubleshoot though. If I put the other springs in that have the Teflon pads, I'm willing to bet the noise goes away
Old 03-13-2015, 10:23 PM
  #40
muddpigg's Avatar
I know this is an old post.
Did you figure this out.
My shackles tend to loosen but the presentation is different. Though we run different set ups.
Quick Reply: SAS clunk.....clunk.....bang....
