Can I use an FJ 40 front axle on my 94
Old 12-13-2007, 09:18 PM
premirrider's Avatar
I was wondering if the pumkin would match up on an FJ 40 front axle and my 94. I could get a steal of a deal for one to use on my sas. Or are they're any other things that would be differnt?
Old 12-13-2007, 09:23 PM
AxleIke's Avatar
The diff is on the correct side, if that is what you are asking. You will have to check on the spring perch location, and move them if they don't match up. There may also be issues with steering. Look into it.
Old 12-14-2007, 04:04 AM
Yoda's Avatar
Hope you are looking at the disk brake axle
They do use a 9.5" R&P. 76 is first year for disks. 2/79 they went to larger birfields (same size as mini trucks). Wheel backspace has to be 3 1/2" to fit on without hitting tierod ends. (yours are about 4 1/2") Less choice for lockers
FJ60 axles have the same issues, just 3" wider
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
Cabell
07-24-2015 12:14 PM
Quick Reply: Can I use an FJ 40 front axle on my 94
