91 sas yota
Old 12-31-2015, 10:41 PM
91SASYOTA's Avatar
91 sas yota
Okay so my truck has a insane death wobble and I have narrowed it down to the fact that I need to get shims to fix my steering angle....But I don't know what degree shims to get????Any help guys???
Old 01-01-2016, 12:18 PM
Fossilized
Staff
dropzone's Avatar
Try 4Crawler.com
I think Roger has a way to determine angle and he sells shims.
Just curious how you determined you need shims?
Death wobble can have multiple causes:
Bad tie rod ends, steering box play, wheel bearings, tires out of balnce, spring bushings, loose shackles
Trunion bearings...
Old 01-01-2016, 10:38 PM
BlackStone's Avatar
^^^ Like mentioned above. Try to Jack up the tires and wiggle them in out to check for play on the TE's. Bushings, and shackles. DW usually isn't as much of tire/s being out of balance as it is the Bushings and TE's, from my experience.
do you have an angle finder?
Old 01-02-2016, 12:14 AM
91SASYOTA's Avatar
Originally Posted by dropzone
Try 4Crawler.com
Trunion bearings...
I've checked everything else only thing I haven't checked is my shackles
Old 01-02-2016, 04:44 AM
Fossilized
Staff
dropzone's Avatar
My death wobble was due to spring bushings being shot, had to pull them out to find where they were split.
A few months later it came back, this time is was broken trunion bearings- to determine that the Tie rods had to be disconnected from the steering arms.
Who did the SAS conversion?
Dave's Off Road has anti death wobble shackles (may take awhile to get)
http://www.davezoffroadperformance.c...-shackles.html
oldspice
01-19-2016 03:53 PM
Yotapower01
12-29-2015 01:58 AM
Jason19r
12-25-2015 04:50 PM
grotto
12-24-2015 01:24 PM
kioti
12-10-2015 12:24 PM
Quick Reply: 91 sas yota
