93-98 T100s All T100 trucks
Vapor Pressure Sensor?
Old 03-05-2012, 10:42 AM
FoCo_4_Low's Avatar
Hi guys!
I'm still trying to track down an electrical short in my coolant temp. sensor circuit. The wiring diagram in my manual shows that the sensor has two wires, one running to the ECU and one running to the vapor pressure sensor. After doing some research I am confused on what the vapor pressure sensor is and where it is located on the truck. My manual shows that it is mounted to the firewall above the brake master cylinder, I can't find anything there. Some sources indicate that there is a vapor pressure sensor in the fuel tank. Does anyone know what this is and where it is located on a '95, 3.4L, 4x4.
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
calderp
07-27-2015 09:58 AM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Vapor Pressure Sensor?
