Rear Axle Seals - Revisited
I know this was in an old thread, but certainly relevant.
http://www.trademotion.com/partlocat...97&catalogid=1
Are these the Toyota parts needed to fix the leaky axle seal? I am very surprised they are less then elsewhere, or are they incorrect? Anyone have the actual Toyota part numbers for these axle seals, o-rings or whatever they are called?
if these are the correct seals for the axle, it might make it easier for people to find them.
Ps. Mine are blown so I need the info as well.
Yup, yup.
Is that yup, yup, meaning those are the correct seals to do the axle seal replacement job? Should anything else be done aside from the oil brake shoes at the same time?
If that is what the parts diagram says, then that's probably what you need.
What are "oil brake shoes" by the way? Yes, you may need to put new shoes in the rear drums and check all that stuff, also. Be sure your wheel cylinder isn't the culprit, though. You just might need to start tearing that thing apart and take a good look at it.
jerusry
10-19-2015 05:28 PM
Iceman4193
07-15-2015 04:48 PM
