| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Marshmallow brakes
#2 (permalink) | |
How's your rubber brake hoses? They can be damaged inside and swell but not leak. Or maybe you haven't actually gotten all the air out of the system. Do you get good pressure out of each bleeder?
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
#3 (permalink) | |
Don't see that problem
Quote:
Having done the bleed job alone, I can't really tell about the pressure at the nipples. I don't have a brake pressure tester. Maybe I can borrow one. I would like to calibrate the load balancing valve. jrohland |
#4 (permalink) |
Try that
I got a used MC from one of the Yotatech members for a good price. When I get it, I will try that. If it does not correct the problem I will keep going with other components.
jrohland |
#5 (permalink) | |
Quote:
#6 (permalink) | |
Well not quite
Quote:
While faulty MC is near the bottom of the list, it is there. Actually, the MC is two MCs connected together. I believe the rear brake piston is not working. At any rate we will know when I replace the MC. If the brake feel more solid, there was a problem. If not, that was not the problem. jrohland |
#7 (permalink) | |
Quote:
gNARLS. |
#8 (permalink) |
How good was the fluid flow when you were bleeding out the rear brakes? Did it come shooting out or did it sort dribble out?
![]() Spongy = air in the system... I had the same symptoms as you did on my 1993 T-100...I started by replacing my MC first as well. It ended up being that there was crud stuck in the LSPV and not allowing proper flow to my rear brakes. I found a simple test to see if the LSPV is doing it's job. Chock the front wheels. Release the parking brake (if applied). Jack up the rear by the differential. Put the trans in neutral. Spin one of the wheels by hand. Stomp on the pedal. If the wheels do not stop...it's most likely the LSPV/bleeder valve needs a good clean out. I whacked the heck out of the LSPV with a 2x4 and then bled it out. The time before...nothing came out. After the "persuasion" with the 2x4, fluid came shooting out along with a ton of air bubbles. Moving to the rear brakes...got more air and lots of fluid flow. Pedal was gitting firmer. Back to the LSPV fer a little more air bubbles and strong fluid flow! Pedal was really firm now. Bled the fronts and system was darn near perfect! That's my story...
#9 (permalink) |
make sure your rear shoes are adjusted properly, if not, i've seen them cause funny pedals.
#10 (permalink) |
Check rear shoes and the crappy LSPV- Most likely that's it- Same problem on my T
__________________
00 Tundra Stonewell Body Ready for shoeing 97 T100 Under the Knife! I am the Toe Cutter! Have you seen the Night Rider? |
#11 (permalink) |
Tight shoes
The shoes are new and adjusted properly. The LSPV is a possible problem. When I bled it I had to take the nozzle out and drill the rust our of the bleed holes. It bled OK after I cleared the nozzle but it could be gummed up inside the valve.
Like I said I am getting a good master for cheap so I will start with that. If it does not fix it the LSPV is next on the list. Thanks for the help, jrohland |
