| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine Troubles
#2 (permalink) |
What broke on the motor? The heads may be worth something, for instance.
If it doesn't stick to a magnet it is probably aluminum. |
#3 (permalink) |
stainless steel is non maganetic, and worth more then aluminum.
What happend to the engine and why cant it be repaired? I have a 96 and would like to know. How many miles on it?
__________________
96 White T100 4x4 Extracab, Lifted, locked, & 35s Currently out of service due to roll over. Pending body work, SAS and rollcage |
#4 (permalink) |
head castings=aluminum
pistons=aluminum block casting=cast iron crankshaft/rods/wristpins/rings=steel camshafts/valves/springs/retainers/keepers=steel those are the major parts of the engine and what they are made of, I'm also curious to what happened, if the heads are undamaged they are worth much more than scrap
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toyota 3S-FE engine troubles | CMD93 | Off Topic Talk | 4 | 11-06-2007 11:00 PM |
| 85 wont run, engine troubles | thebeast8888 | 84-85 Trucks & 4Runners | 8 | 06-18-2006 02:46 PM |
| engine troubles | atarinaper | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-13-2003 02:07 PM |
| HELP! Manual Transmission Troubles- won't shift w/engine running | smwells | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-08-2003 07:29 PM |
| cold engine troubles | Skydigger | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-08-2002 04:46 PM |
