93-98 T100s All T100 trucks
98 T100 brake/marker/ tail lights not working
Old 04-12-2015, 04:35 PM
BOGDOG's Avatar
Having issues with lighting on my T100. Everything was working then I discovered brake lights weren't working. I poked around fuses are good I have power to switch switch seems to function properly. Today I pulled taillights and discovered tha taillights and front marker weren't working either.Is there a common ground point for these lights? I see separate wires to each socket in taillight housing.
Old 04-13-2015, 03:23 PM
CJM
CJM's Avatar
Got a trailer setup? Check the grounds on that, also see if the trailer connection (if you have one) is wired into the light sockets themselves. I had a weird issue where my entire truck blinked in unison with the blinkers. Removed the trailer connections that were inline to my lights and problem went away, put a new setup on and no issues.
Old 04-15-2015, 03:24 AM
BOGDOG's Avatar
no lights
No trailer wiring. I am thinking it has something to do with the stupid lighted washer fluid squirters. Got some funky wiring going on. Can't see where it's tied in.
06-01-2021 01:51 PM
gillesdetrail
11-19-2019 12:56 PM
colinmil
07-06-2015 04:03 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 98 T100 brake/marker/ tail lights not working
