| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Help!!!!! Electrical problems overwhelming
__________________
87 4runner, red, rebuilt 22re, 2" manifold back dynomax exhaust, 31x10.50x15 Pirelli Scorpion Mud tires on 15x9.5 aluminum American racing rims, diff breather mod, double tow hook mod, auxiliary fuse box, shop class rear bush bumper, Alpine head unit, nice red led glow in foot wells front and back, custom cargo lights, rest stock 3 33X12.5 mudders waiting to go on rims for spares |
#2 (permalink) |
Did you swap the alternator with a new one ?, if you swapped in a used alternator are you sure its good ?, check all the ground wires under the hood, another up grade you can do is change the wire that comes out of the fuse box by the battery to a heavier wire, that little wire is the only thing charging your battery and its way to small to keep up with heavy charging demands. if all else fails you can upgrade to a 100 amp MR2 alternator.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#3 (permalink) |
You don`t say where you pull power for your extra power distribution block. It should be right off the battery
The Transmission because of being electronic control can get a little finicky if the voltage drops to low . You upgraded your grounds to welding cable did you crimp on the lugs I use marine battery terminals to make it easy to add extra wiring . All in all some where you are not getting the correct voltage. It also sounds like your battery is not picking up the load like it should . This will be hard to find or deal with if you don`t have a Multi meter . you need to know the voltage at the battery under normal winter load . @ 2000rpm you should have between 13.5 to 15 volts DC These alternators do drop off at lower rpm that is when your battery should pick up the load . Now if you are talking temps of 30 below F all electrical things act finicky Hope this helps |
| Tags |
| 4runner, bright, dim, electrical, electricians, find, forums, lights, mr2, problem, problems, starting, thread, tool, tools, toyota |
