General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Ground point in fuse panel, 3rd gen t4r
Old 10-08-2012, 09:00 AM
Yotadawgjr's Avatar
Bought a small digital voltmeter from ebay, which I'm mounting above the fuse panel in one of the switch blanks.
I have a fuse tap (add-a-circuit littlefuse type) which I will be plugging into the fuse panel somewhere, providing a connection for +power, and measure lines on the volmeter.
I'm wondering where the easiest place to attach ground wire in the fuse panel area...there's a few screws holding the fuse panel in place, maybe those are good enough?
Originally I was going to wire everything straight to the battery, but I'd rather not go to all that trouble just for a small current draw device.
Old 10-08-2012, 02:50 PM
habanero's Avatar
There's a good spot just behind the kick panel right next to and below the fuse panel.
Old 10-09-2012, 10:47 AM
Yotadawgjr's Avatar
voltmeter installed
Perfect, thanks for the good description, found it easily.
Here's the finished install if you are curious:
should come in handy in the winter, when my truck sometimes sits for a few days in cold temperatures.
06-01-2021 01:51 PM
v_man
07-23-2015 04:01 PM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
Sandman
07-14-2015 12:36 PM
Quick Reply: Ground point in fuse panel, 3rd gen t4r
