GlowShift Products - what do you guys think?
Hi guys,
Looking to pick up some parts for setting up electronic gauges in my 87 4runner, and came across GlowShift. Saw some posts here that mentioned them but nothing specific to quality/price.
I'm looking to get:
Oil sandwich adapter with NPT fittings for a sender:
http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
Water hose adapter with NPT fittings for a sender:
http://www.glowshiftdirect.com/28-mm...achment-1.aspx
Plus, I may pick up an oil pressure guage and some sender hardware from them.
Is there stuff pretty decent and are the prices fair? Seem pretty reasonable to me after searching around Summit and other places....
I'm looking to get:
Some sending units come with the guages. I havent heard very good things about that company. Mostly there guages and being cheap. But a sandwitch plate cant be that cheap i guess. The worst it could do is leak and some teflon tape would fix that!
whoa sub'd for later reference.
is it me or did he not have to drain the oil first to remove the oil filter?
http://www.youtube.com/watch?v=fl4cs-EqF1Y
Thanks guys. I watched the video as well - pretty well done. I need to address an oil leak anyway and I'm close to being due for an oil change anyway.
Do you guys know the inner diameter of the top coolant hose on a 22RE by chance? I really haven't checked it out yet
this place says 1 5/16 or about 33mm
http://shop.advanceautoparts.com/1/1...tml#fragment-2
which makes sense my water hose adapter was originally from a honda B16a which is around 3Omm and it works fine
Phil if you do decide to go with the glow shift stuff let us know how it is. I want to do oil pressure, volt and temp. Cause the stock sr5 gauges do not work/suck.
Hey Rich,
I'm leaning toward Autometer, since I have an Autometer A/F and Water temp with gauge pillar in the mail to me from Taro this week - would like it all to match. Just need to figure out what senders to get (1/8" NPT fittings are what I'll get, but there are more than one adapter for Autometer available at Summit - and some are for "pre 1996 gauages only" or something like that....)
Probably going with GlowShift for the sanwich plate, and the coolant hose NPT adapter.
Will report back with pics of course!
Questions (since I suck at this stuff):
- Is plumbers tape the same as teflon tape? Need that for the NPT fittings....
- Anyone have a source for a simple, easy wiring diagram to hook these up to my headlight/parking light/dimmer switch?
- Is there a good rubber grommet area in the firewall on the drivers side for this stuff? I found one on the passenger side that I used recently to pre wire some fog light wires in a loom (1/4" loom is like $10 at Amazon for 100 feet!).
Thanks!
Thanks!
Yes teflon is plumbers tape, white tap, what ever you want to call it. I did not use teflon when I screwed in the adapter fitting for the sending unit. Just something I didn't think was a good thing to do in case some of the tape came off in the hole.
I have a autometer oil pressure gauge also. I got everything from summit. I do not have it permanently mounted in my truck yet. But I did hook it up to test it out.
The adapter number is: ATM-2269 $8.95
That's from my summit invoice.
Thanks Rich!
The oil pressure gauge actually comes with the sender, from Summit, so I'll be good there.
What I'm worried about is the water temperature sender, to match up to the Autometer gauge that's coming in the mail...there appear to be many kinds.
Phil
Well, I went ahead and ordered the oil filter adapter (1/8" NPT fittings) and the coolant hose adapter from Glowshift. I also have in the mail from Summit an oil pressure sport comp oil pressure gauge/sender kit, and the water temp sender.
So now, I'll have:
- Autometer Water temperature electric analog gauge/sender
- Autometer Oil Pressure electric analog gauge/sender
- Autometer Air/Fuel gauge....I downloaded the instructions for this thing and can't tell if i need a wideband O2 sensor for this, or if I can use my OEM one (it reads between 0 and 1.0 volts from the single wire O2 sensor, so maybe I can use the OEM sensor/wire - anyone know???)
- Gauge pillar
I plan to install the pillar/wiring/gauges this week at my in laws and do the sensors when I tackle my oil leak/timing cover issue in the next month or so. I'll get pics up of course.
Questions:
The autometer gauges say that you need to ground them "near the sender". I also read on Autometer.com that senders like oil pressure ground themselves through the threads - I get this, but how does it ground itself if the sender wire is ALSO attached to the sender - do they attach in 2 different places? Is there any interference? On that note, could I conceivably run one ground wire from the cab to the oil pressure sender, and then ground my other 2 gauges in the cab off that same wire (all sharing the ground with the oil pressure sender?).
And, for lighting, what's the best way to tap into your factory dimmer switch to get power when the lights are on, as well as the dimming feature? Do you hook in the ground to the dimmer wire (which one?), and the positive to the headlight/parking light hot wire?
Sorry for all the questions guys - just want to approach this the right way and I'm terrible at wiring thus far.
Thanks
So now, I'll have:
- Gauge pillar
Questions:
Thanks
Thanks Outsane.
Any reason it has to be grounded *close* to it? Aren't all grounds...grounds, and couldn't all the gauges share the same ground with one another? That's what I'm getting at. For the water temp sender, I'll have the adapter in the upper radiator hose - where would I ground it nearby (what do you recommend)?
Hey guys....
at the in laws and the new oil pressure gauge kit arrived - wahoo! Plan to run the wires and install the gauges tomorrow. I want to make sure I get the wiring correct. After reading the Automter installation guide online and that came with my oil gauge kit, this is what I think I'm going with:
Is this correct?
Also wondering, where in the cab I need to ground everything (lighting, gauges)?
And....any tips on hooking into the factory dimming switch?
Phil
Is this correct?
Phil
