YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-20-2008, 10:33 AM   #1 (permalink)
98 4Runner Window switch slowly going out?
I have a 98 4-Runner and the windows are slowly not responding to the switch, either the master, nor the local door switch. The driver's side front works fine, and the passenger's rear works fine as well. The problem is that the driver's rear stopped responding to the switch, and about a month later, the passenger's front stopped responding and now the window is stuck down, but if you press "down" on the switch, it goes down just fine. I should add that the "up" function worked well and was not sluggish before it stopped responding.
What could be the problem, and how can I get the window up at least manually for now?
Thanks for any responses.
Poindexter
Poindexter is offline
Sponsored Links
To remove this ad, register today!
Old 08-20-2008, 10:40 AM   #2 (permalink)
okay,i am no expert, but when you press the switch on the windows that dont work, can you hear the motor in the door?
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is offline
Old 08-20-2008, 10:57 AM   #3 (permalink)
4biker's Avatar
I had a similar issue in a Ford Ranger. I pulled the switches apart and cleaned the contacts and it worked fine after that. You also may have a loose wiring harness or bad contacts there, since it's multiple windows that are affected.
If you hear the motor running in the door (like 904_runner said), it could be a bad motor or regulator.
Let us know what you find out!
__________________
1997 4Runner Ltd, E-locker, OME 881/906's with black Tokico's, 265/75/16 Yokohama Geolander AT+II's, 1000w inverter, dual batt setup
My Profile
1998 Rocky Mountain Element TO (Canada Red)
4biker is offline
Old 08-20-2008, 11:39 AM   #4 (permalink)
Joe's Toy's Avatar
Poindexter
Hey Poindexter, I just got my truck back from the dealership because my passenger rear window stopped working w/ exactly the same symptoms your describing. (I took it to the dealership because I have it all under warantee) It turned out to be just the switch, they replaced it and sent me on my way.
__________________
"And they called him a Hebrew Slave"
2003 Tacoma Prerunner, Double cab, 3.4 V6 5VZ-FE, auto. 2wd, rear e-locker
My Profile
(06/09/07)-Deckplate-(07/14/07)-ISR-(08/27/07)-WARN 4300K HID lights-(11/22/07) -True-Cool Tranny Cooler-(12/25/07) -Tru Flow air filter-(12/25/07) -Husky Floor Liners-(02/14/08)-ScanGaugeII-(04/30/08)-Glassworks Unlimited hood-
Joe's Toy is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
WTB: Rear Window Switch 88 4Runner 4RunnerFreedom Misc Stuff (Vehicle Related) 6 08-07-2008 02:16 PM
01 4Runner master window switch NorCalVP Misc Stuff (Vehicle Related) 0 10-19-2007 09:41 AM
85 4runner rear window switch question mean green General Vehicle Related Topics (Non Year Related) 1 07-13-2007 03:13 AM
4runner Rear Window Switch 95 90 91 92 94 93 CDUFF7 Misc Stuff (Vehicle Related) 1 11-08-2006 03:15 PM
4runner Rear Window Switch CDUFF7 Misc Stuff (Vehicle Related) 0 02-19-2006 08:52 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
