YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-30-2008, 01:21 AM   #1 (permalink)
87 4Runner brake lights inop., not the fuse or lights. What next?
A few locals have politely yelled at me concerning my brake lights, particularly due to the fact that they don't work! I was just pulled over only a week ago for a license plate infraction; so i am confident that they worked then, or the officer surely would have told me.
So, i figure that the problem has risen from a long weekend of wet wheeling at moonrocks, NV.
This is an 87 4runner. The signals and running lights work, but only the brake lights fail to illuminate. I've checked the #9 fuse and replaced both lights, to no avail. So, my hunch is the wiring or activation switch is at fault. The brake actuation switch is clearly being depressed and released upon pedal movement, but the short time i've spent under the dash hasn't turned up any more than a bit of frustration.
Where would you fellows think i should continue to diagnose the problem? Until then im stuck with hand signals.
Mike
predballer is offline
Sponsored Links
To remove this ad, register today!
Old 05-30-2008, 08:18 AM   #2 (permalink)
eric-the-red's Avatar
Get a multimeter and start checking for power in each part of the circuit. Check both sides of the fuse, then the switch and so on down the line. When you find where there is no power that is where the problem is. If you have power going into the switch and not out then jump both terminals on the switch with a piece of wire, if the lights go on then you know it's the switch. If the switch and fuse are good then you probably have a broken wire. Those can be lots of fun tracking down, might be easier to just rewire the brake lights if that's the case.
Another thing is if you have trailer wiring disconnect that temporarily and see if that helps.
eric-the-red is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Reverse lights inop! rollem 86-95 Trucks & 4Runners 13 04-25-2007 08:55 AM
VSC lights, ABS lights, No Front Brake Info after Lift Edrake 03+ 4Runner/GX470, & 05+ Tacomas 1 12-08-2006 03:48 PM
HELP-Fuse for Gauge Lights?? 964runner 95.5-2004 Tacomas & 96-2002 4Runners 3 09-21-2005 06:05 PM
taillights, corner lights, gauge lights are out - not fuse 2WICE 95.5-2004 Tacomas & 96-2002 4Runners 11 05-12-2005 02:54 PM
1990 4runner ELECTRICAL PROBLEM with front and brake lights shoei 95.5-2004 Tacomas & 96-2002 4Runners 5 02-22-2004 07:46 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
