General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
81 will not shut off when ignition switched off
Old 09-22-2014, 07:50 PM
Fossilized
Staff
dropzone's Avatar
Ok got an electrical issue I hope you guys can help me out with.
Over the past few years my truck would intermittently not shut off when the ignition was shut off with the key. Now it never shuts down with ignition off. I have to step on the brakes and slowly let the clutch out. Obviously not ideal or safe.
I have traced wires (look fine), checked grounds, and replaced the switch in the column. No luck. Have not replaced solenoid or starter. Starter works fine, not sticking etc.
Any suggestions? 1981 Toyota with L52, 22r
Old 09-22-2014, 08:00 PM
millball's Avatar
Does the battery discharge when the key is off after shutting down with the clutch??
Old 09-22-2014, 08:18 PM
Fossilized
Staff
dropzone's Avatar
Nope. Truck has sat for a few weeks before and started right up after using the clutch shutdown method.
Old 09-22-2014, 10:01 PM
totally a bro
Staff
vital22re's Avatar
Does the ignitor/coil still have 12v to it once key is turned off? or is it "dieseling"
Old 09-23-2014, 03:08 AM
Fossilized
Staff
dropzone's Avatar
With key turned off it continues to run like normal, no sputtering like it is dieseling, so yes it still has power to coil based on that observation. Haven't measured power.
Old 09-23-2014, 09:05 AM
millball's Avatar
Sounds as if a power source (Relay or relays??) is improperly holding in until the alternator stops producing power.
Old 09-23-2014, 09:41 AM
Staff
kawazx636's Avatar
I think this your your truck's way of saying "drive me more often damnit!!"
I bet Don (Suncomb) could point you in the right direction - he always has the answers to my electrical woes. You oughta shoot him a PM
redneck17
08-12-2015 08:15 PM
redneck17
08-05-2015 10:03 AM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 81 will not shut off when ignition switched off
