Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Rear Differential Breather Mod
Jackson (jacksonpt on the forums) shows you how he hooked up his rear differential breather for safer water crossings. Extending the rear diff breather line is a must-do mod. It's cheap, easy, and quick and requires next to no mechanical expertise. It cost me all of about $20 and 30 minutes of my time. I ordered 2 parts, a union fitting used as an intake manifold fitting (part number 90404-51319) and a small breather plug (part number 90930-03136) from toyotaparts4u.com for about $12 shipped. I also picked up about 6 feet of fuel line for about $6, and a 4-pack of small hose clamps for $2. Both came from AutoZone. I dropped the spare tire to give myself some room to work (it's kinda funny... with my lift, and the rear tire dropped, I can sit up straight underneath my rig-I think it's funny anyway). I used a small adjustable wrench to remove the old breather filter, and replaced it with the union fitting. I then attached one end of the fuel line to the fitting, and secured it with a small hose clamp. I ran the hose along the brake line and up the gas tank fill tube, leaving a little extra slack to allow for axle drop. I used zip ties to secure the hose. I then opened the gas hatch and removed the rubber fitting around the fill tube (NOTE: do not try to loosen the nut for the release latch. There is a tension cable used to control the latch that is easily dislodged-I know from experience. The tension cable can be re-seated, but it's tight working in there.). I fed the hose out through the opening and attached the new breather plug and used another hose clamp to secure it. I then ziptied the hose to the fill tube to prevent and rattles. Breather Plug (part #90930-03136) Union fitting (part #90404-51319)
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! |
| Sponsored Links |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Differential Breather? | Chrisnxl185 | 86-95 Trucks & 4Runners | 19 | 12-07-2007 12:34 PM |
| Rear Differential Breather | rearviewmirror | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-19-2006 11:47 AM |
| For Those Who Are Going To Do The Differential Breather Mod.... | fireteacher | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 04-17-2006 06:56 AM |
| Differential Breather Mod w/pics | <96 Runner> | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 03-10-2003 07:05 PM |
