Removing Broken Inner CV Axle Shaft - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2008, 02:39 PM   #1 (permalink)
Vermejo's Avatar
When the CV breaks at the inner axle shaft extraction or teardown are the two options. The broken shaft in inaccessible by simple measures.
-Jack and support front end safely
-Remove tire, damaged CV and shock assembly (Plenty of write-ups on CV removal)
-Mark and indent center of broken shaft
-Wedge paper into the bottom of the housing to catch metal shavings
-Make sure your drill fits into the tight space at a straight angle. If the drill does not fit removal of the LCA is required. The DeWalt I used was big and had to be operated upside-down to get a straight line on the shaft
-Use a 5/16 cobalt/tungsten carbide tip bit for drilling. Drill a pilot indention with 4WD disengaged to spin the shaft and center the hole more easily
-Engage 4WD and front locker and drill approximately ½ inch deep
-Start the 3/8 tap by hand and continue with a wrench. Back the tap out every so often to clean the threads and clear metal particles, wasted gear oil will assist the tap
-Thread the 3/8 bolt and remove the shaft with a slide hammer. The Harbor Freight model I used was 3/8 and threaded directly into the shaft. Otherwise use a 3/8 bolt and slide hammer jaws. (in the tools pic note the shaft piece at the end of the slide hammer)
-Thoroughly clean the housing to remove any shavings/debris
-Change the diff fluid and check the drain plug for metal after a few miles if need be
__________________
1998 LTD|DoubleLocked|Yukon 4:88's|BFG KM2 315|SMP Bumpers & Armor|Sonoran Steel Lift & Links|BudBuilt Skids|WARN Recovery & Hubs
Vermejo is offline
Tags
4runner, 96, assembly, axle, axles, broke, broken, cv, pic, removal, remove, removing, shaft, tool, tools, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Broken "inner axle" shaft at front diff! Issues 86-95 Trucks & 4Runners 13 10-02-2008 10:29 PM
broken drive shaft??(camping trip fun!) rocklover 84-85 Trucks & 4Runners 14 08-04-2008 09:51 PM
Removing broken studs Kiff 86-95 Trucks & 4Runners 0 02-23-2008 05:53 PM
Drive shaft questions (broken cardan joint?) androtaker 95.5-2004 Tacomas & 96-2002 4Runners 6 06-06-2007 10:45 AM
88 axle housing.........90 axle shaft....Fit? Yoda Offroad Tech 1 12-10-2005 10:36 AM
2009 InternetBrands, Inc.
