| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
"Two wrongs don't make a right, but three rights make a left." 1988 4Runner -- 22RE 5-speed manual | 210,000+ miles |
#2 (permalink) |
de icer always works around here..ut it doesn't get below zero here lol
maayyybbbeee...some kind of lubricant?..spray it on every now and then? idk
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 4runner V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#3 (permalink) |
Try WD-40
__________________
1985 4runner 22re 5spd. |
#4 (permalink) |
Maybe some silicone oil or some graphite would work.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#5 (permalink) |
Wd-40 is what you want. It disperses the water so theres nothing to freeze up.
Just stick the little hose into each lock, spray a little, wait, spray a little more then work the key back and forth. Do this 2-4 times to all your locks. Should clean out all the gunk too!
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 255k |2.25" catback w/ magnaflow cat + no muffler | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's and 700ffs |4" reverse lights| Grant GT |idler arm brace| E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
| Tags |
| 4runner, door, free, freezing, key, lock, locks, lube, lubricant, lubrication, lubricator, spray, tailgate, toyota, winter |
