Are U satisfied with your aux. lighting??
#42
Originally Posted by lee
damn, those are huge, aow... ever gotten pulled over? those seem to be too big/bright to be legal!
They've never been an issue. I only use them on dark, back roads or on long stretches of highway with no opposing traffic within a mile or so. Sometimes I'll leave them on even with opposing traffic if there's a substantial highway divider. These things pack some serious output. On a pitch black night, you could stop the truck, turn the lamps on, hike a mile down the road, take out a book, and start reading. Never had reason to do that though...
I've also had them mounted for more than two years now without a single rock chip or crack. I've left the large Hella white covers off since new as I felt they would draw more attention to the lights and end up stolen. Love 'em.
Andreas
#43
Senior Member
It's not so much the light itself, it's how/when you use them. Check with your local laws, but from my experiences, in most places, it's illegal to use any aux lighting over 65w. Anything over 50 needs to be used light high beams. And most states have limits as to how hight the lights can be mounted.
My 4000s are 100w each, and I've got 330w worth of light on my roof rack. I use them very responsibly, but I do use them. I've never had a problem.
#44
Originally Posted by bulletproof
just wanted to see what people are running on roof racks, tjm,grill gaurds ETC.
i am considering 4 hella 500s up top on the rack and a pair of lightforce 240s on the front bumper .
anybody have anything bad to say about the lightforce , i havent heard or found anything negative yet on lightforce , BUT FILL ME IN ON WHAT U THINK AND WHAT YOUR USEING
The adjustable beam is an awesome feature.
#45
aaAAHHHHRRGGGGG ,more lightforce info :HELP:
Pretty cool.
#47
I've got some IPF fogs in the bumper and some IPF 900 driving lights on top of it. The fogs are standard 55w H3 bulbs, but the 900's are 130W each. Nice and bright - and hooked up to my bright light circuit so they come on when I hit the high beams (switched conn of course). About $250/pair w/ wiring harness and relay. Click the pic for a HUGE image.
#50
How do the Lightforce lights work in the snow and fog compared to just regular fog lights? I like these lights and contemplating between the 170's and a set of piaa 525's, anybody have any input?
#52
A pair of 170's are kicking out 1,000,000 candlepower which is a boatload more than a standard set of fog lights. I have mine adjusted for a pretty wide flood pattern, and the difference is incredible. In decent fog, I can easily light up a swath of road that's 50' wide and 40' out. And "light up" means "lookin' like daytime" (though with a yellow tint).
In simple darkness, the effect is much more dramatic. Coming down a trail in the middle of the night isn't an issue. I can get light everywhere.
#54
i'm running the Hella 500's as well...
fogs on the outer and driving (pencil beam) in between. Hellas are very affordable and work great. I mounted the toggle switches just forward of my gear selector looks really clean.
#55
OK But are they too powerful for fog? Like turning on your high beams? I'm not trying to hijack this thread just get info on the lights.
Lightforce also offers Clear, blue, red, and green lenses for the 170s. Each have their purpose - it's not just for bling.
#56
Originally Posted by midiwall
Nope, and it's because of the yellow light. Your highbeams are bad news 'cause the white light reflects off of the fog and creates all that glare. Running a yellow filter with the 170's makes them into fog lights (maybe I should have made that clear before) and the yellow light doesn't create glare.
#57
In my opinion I have yet to see a 55w bulb that at the same time a) makes much of a difference, and b) is worth the cost. I run overwatt 100w highbeams as well as 2 130 6" H3 lights on the road all the time and the only reason that I don't have more is because the stock 60A alternator can't hack it and still have anything left to run stuff like the sterio.
For anyone looking for better lighting that is not glaringly obvious I highly reccomend the Bosch H3 converson for the older sealed bulbs. I run 80w/100w and have never had a problem with cops even running the 80w low beams everyday around town. The Beam pattern is excellent and projects a low flat low bean that is aimed properly won't hit the rear window/rearview mirror of even the shortest cars, while the highbeam pattern is great. Both wide ditch to ditch and far penetrating. I have driven through numerous police checkpoints without even a second look. You just have to be extra careful that you remember to dim your lights to not highbeam oncoming traffic.
#58
#59
what I did was go with hella h4 replacement headlights with 55wat low x 100wat high beams work great. with set of kc day lighters 100wat wired them thru stock chevy foot dimmer switch I do a lot of baja drive it works great for dimming light with out takeing hand of steering wheel.
