Timing Belt with marks????
where do i get one of these for a 3vze?
in the fsm it talks about marks on the belt to help line everything up when installing. well i went to autozone and kragen and neither places had the belt with the marks. i also went to toyota and same deal no marks on the belt. and YESSSS i did seach and found nothing
There isn't really a need for the marks. Just make sure the cam and crank are correct, and you could concievably make your own marks but its really not necessary. One revelation of the crank and the lines will be off anyways, since the crank spins 2:1 to the cams.
crashburnoveride
07-10-2015 06:39 AM
