Leak on rear axle but from what???
Old 08-19-2012, 09:46 PM
mcclimber's Avatar
I have a 1996 Toyota T100. Saw this leak on the rear axle on the drivers side but do not know the cause. Shock looks fine but old. Brakes feel fine and reservoir fluid looks fine.
Thanks for looking and some ideas.
Old 08-20-2012, 05:44 AM
waskillywabbit's Avatar
Is it oil or brake fluid? Looks to me like axle housing is seeping at the perch mount.
:wabbit2:
Old 08-20-2012, 12:39 PM
mcclimber's Avatar
I did try to find a good drip to see what kind of fluid but no luck. Pretty dirty there too. I am checking it before and after driving.
Thanks
Old 08-23-2012, 05:07 PM
mcclimber's Avatar
Is there anything I can do? Id there much to worry about?
I keep a regular maintenance schedule and the rear diff is topped of with oil.
Old 08-24-2012, 06:29 AM
nobb's Avatar
Did you clean it first to make sure it actually is a leak?
Old 08-24-2012, 07:07 AM
badattitude's Avatar
looks like it is leaking from the brake line clip. The bolt that holds the clip in the axle housing. Maybe take out the bolt and take a look. Then clean it off and reinstall that bolt with some blue loctite. Thought being the leak is comming from the hole the bolt is in perhaps. The loctite will act as a stop leak?
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Leak on rear axle but from what???
