If you had a 1000 dollars to spend...
Old 12-02-2010, 07:08 PM
AssYriaNrocKer's Avatar
Originally Posted by snobdds
gears and a rear locker, front if there is some left over cash.
x 2!!
Old 12-02-2010, 07:27 PM
duck tape's Avatar
L s d
Old 12-02-2010, 08:55 PM
blueyota4x4's Avatar
1uzfe swap!!
Old 12-02-2010, 09:23 PM
peow130's Avatar
Find a matching set of gears..
Weld the front (because who really needs to spend money for a gearset that only sees activity 10% of the time it's driven)
Buy some cheap 33's..
Buy some steel and fab up some sliders, and a bumper.
Old 12-02-2010, 09:36 PM
  #25
Teuf's Avatar
If you find CHEAP 33's let me know.
Old 12-02-2010, 09:41 PM
  #26
peow130's Avatar
There WAS a set up north from me for some 33x12.5 BFG A/T's at about 50% tread on some wagon wheels for 200 bucks :/
Post was a month old when i found it.
Check craigslist lol
Old 12-02-2010, 11:52 PM
  #27
drew303's Avatar
buy a Jeep
Old 12-03-2010, 01:54 AM
  #28
SoCal's Avatar
I had always found an excuse to put off doing gears, but Once I did it. Now I think it is the single most impressive modification anyone could do. Gears with a Spool that is.
Old 12-03-2010, 04:12 AM
  #29
bryan89's Avatar
Originally Posted by drew303
buy a Jeep
....dude wtf? lol you cant be serioius. any thousand dollar sheep is gonna be a rust bucket. even if not, you still have a weak and worthless jeep.
lol i would rather piss a grand away on strippers and beer than buy a jeep.
Old 12-03-2010, 06:35 AM
  #30
highonpottery's Avatar
Depends on what you want to do. I would say if you're doing any crawling to get a locker, sliders, low-profile t-case crossmember, and high clearance rear bumper for $1k. Tires and gears would be the next $2k, then the next $1k might consider front locker and some gears or front bumper and winch.
If you're doing non-rock wheeling then I would go for lockers F/R and a set of mud tires in like a 31" tire since you wouldn't have the gears to run larger. Next $2k would be gears and bigger tires - if you sell the old tires you might be able to get a mild lift too.
Old 12-03-2010, 06:50 AM
  #31
toyospearo's Avatar
Miller 180 welder!
My Miller has saved me THOUSANDS of dollars on my builds. Best purchase I have made!
Old 12-03-2010, 07:00 AM
  #32
^that's a good one right there. For someone like me though it would cost more than the $1k for a welder since my garage would require a new subpanel in order to run the thing.
Off to buy lotto tickets...
Old 12-03-2010, 09:27 AM
  #33
Alex123456's Avatar
dual cases and a locker
Old 12-03-2010, 12:51 PM
  #34
peow130's Avatar
Actually ill change mine.
If I had a grand id finish up my heep.
Old 12-04-2010, 05:15 AM
  #35
bone collector's Avatar
Wow lots of good ideas on here. i was thinking i would do BJ spacers and diff drop from 4 crawler find a set of 4.88s out a junkyard or donor vehicle and replace the ball joints and tie rod ends etc.. while im at it. then probably add a set of shocks with what i got left over. Cuz mine are basically non-existent.
Old 12-04-2010, 05:40 AM
  #36
yotarob2005's Avatar
Originally Posted by bryan89
the very first thing i would get is a set of nice rock sliders. im not out trying to destroy my vintage trucks body parts for sure.
then maybe a nice skid or bumper.
i would do the protection first. here is why. with the gears and locker you are going to be able to tackle some obstacles that your otherwise stock truck would not, obviously. bigger obstacles comes with bigger drops. bigger slams. bigger dents.
so protect then upgrade capabilities in my opinion.
^^ this. Always armour first! I learned that the hard way.
Old 12-04-2010, 05:51 AM
  #37
hyzerponix's Avatar
My '83 is pretty much stock, but I would like a set of OME springs/shocks to help offset the load of the new plate winch bumper that's going on my truck.
Old 12-04-2010, 07:53 AM
  #38
toyNG's Avatar
With the exception of tires, every thing you see in my sig line was about $1000. But I did get the tires at a ridiculously low cost of like $79 per brand new tire. I bought everything used, except for the t-case gears and the sliders. I was in no rush, so I waited around for great deals on used parts. A lot can be done with not much money.
Old 12-04-2010, 11:45 AM
  #39
dark_fairytales's Avatar
I agree also with the welder. Opens many doors and options you would not have other wise. first task with the welder, build all the armor you need.
Old 12-05-2010, 12:30 PM
  #40
RAMZ's Avatar
First $1000
63inch rear leaf springs
snorkel
and a way to tell the wife "I spent another $1000 on my
truck"..
Quick Reply: If you had a 1000 dollars to spend...
