HELP!!! Mechanic Quote
Old 01-05-2007, 08:41 AM
ErikJeanna's Avatar
I have a quote from a machanic for some work on my rig. My 4Runner is a 98 2wd SR5:
- Rear brakes $431
Replace shoes (under 10% left)
Replace cylinders
Clean & lube insides
Bleed the lines
Machine the drums
- Clean throttle body/injection system $89
(massive carbon buildup)
- Transmission flush with some machine & BG chemical mix $169
(never been cleaned/flushed since 1998)
Is this practical pricing? I'm getting 10% off all labor because I know the guy, but wanted to make sure that this is an OK deal. I know that mechanics have to make money... I just don't want to get screwed. Advise is welcomed.
Erik
Does any of this sound fair? I don't know much about any of these things.
Old 01-05-2007, 08:45 AM
norcalsvx's Avatar
the brakes are a little high but everything else is on par
Old 01-05-2007, 08:54 AM
naksukow's Avatar
Seems about right. How many miles are on your 4runner?
Old 01-05-2007, 08:56 AM
callmej75's Avatar
Dang....I'll do your rear brakes for $300! Shoes aren't that hard to replace...just remember where the springs go and all the other small pieces...but thats why they made a manual for! You will have to get your drums turned at a shop...but thats about it. The rest seems reasonable.
Old 01-05-2007, 09:04 AM
ErikJeanna's Avatar
There are roughly 130k on my runner... sounds like I got an OK deal then. I don't mind paying for work as long as I'm not getting screwed for several hundred dollars.
Old 01-05-2007, 09:15 AM
callmej75's Avatar
Wish I was close to ya...I'd save you a few hundred!
Old 01-05-2007, 09:23 AM
19RUNNER86's Avatar
yeah that seems what a regular mechanic would rape err..charge ya for that stuff.
Old 01-05-2007, 09:25 AM
ErikJeanna's Avatar
Yeah, and I could also get my roof rack powder coated black! That'd be nice.
Old 01-05-2007, 09:29 AM
callmej75's Avatar
True...but I'd need a bigger oven for that sucker!
Old 01-05-2007, 09:38 AM
surf4runner's Avatar
do you see leaks from the rear? likely the cylinders wont need replacing and unless the drums are thrashed (grooved), they probably dont need to be turned (all extra $$ to your "friend")
Old 01-05-2007, 09:40 AM
19RUNNER86's Avatar
if you dont resurf your drums it will stop for nothing in the rear and ruin the new shoes. i would resurf if i were you.
some drunk guy
08-03-2021 06:09 PM
Firefightersink15
11-23-2015 10:32 PM
IntoTheVoid
10-24-2015 04:54 PM
sonorn67
09-19-2015 05:39 PM
dlaiben
3.4 Swaps
09-03-2015 09:57 AM
Quick Reply: HELP!!! Mechanic Quote
