| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sponsoring Member
Do not underestimate the magic of replacing the TPS (Throttle Position Sensor)
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams Last edited by midiwall; 08-02-2006 at 04:51 PM. |
#2 (permalink) |
Well, we're just happy it works again, and that you learned a little lesson mark...
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#3 (permalink) |
Pure Triumph
and I have written that one down...
__________________
Brian 1998 4Runner SR5 |
#4 (permalink) |
yep, the o2 sensor doesnt react nearly fast enough for the ECU to give it priority
#5 (permalink) |
You got skillz Mark.
![]() Question: Is it possible that since the SMT bases a lot of its "corrections" on throttle input, that it was going whacky because it essentially didn't know "where" it was...or simply that it was making fuel and timing corrections at the wrong part of the matrix? I hope that made sense...
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#6 (permalink) | ||
Sponsoring Member
Quote:
Quote:
Actually, I figured you'd ask about this, and the answer is... I don't use TPS for that deflection input - I use the MAF. It gives me the ability to tune for what the engine is doing versus what it "should be" doing.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#7 (permalink) |
Brilliant!
sorry is this has already been covered but, where is the TPS in relation to the TB? Can I only see it if the TB is off?
__________________
'95.5 T100 sr5 3.4L 4X4 |
#8 (permalink) | |
Sponsoring Member
Quote:
It's held on by two philips screws, and if you have a shorty #2 philips, you can get it off without pulling the TB. BUT BE CAREFUL - the heads on the screws are soft, and if the screw is oxidized at all, you run the risk of stripping the heads out. I started to strip a head, which is what prompted me to pull the TB so I could get cleaner leverage on them. When you put it back on, you'll need to note how the "flat" of the butterfly shaft fits into the TPS. The shaft will have a slight spring loading on it, so it will turn about 5* when you pull out the TPS. This is another reason to pull the TB to do this - it's MUCH easier to see what has to happen to get it back on with the TB sitting on the ground.
__________________
#9 (permalink) |
I really need to replace mine. Just haven't gotten around to it yet. I get a TPS CEL whenever I have the diagnostics port jumped and my RPMs around 2700. It pings like crazy right around there too.
Thanks for giving me more reason to get on this!
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. |
#10 (permalink) | |
Sponsoring Member
Quote:
![]() "twinotter"... are you a pilot or do you jump? (or both?!)
__________________
#11 (permalink) | |
Quote:
They used to fly one right over our trees from a little grass airstrip down the road. So cool. I have been to ground school, but I can't afford the actual flight time. ![]() Daniel
__________________
#12 (permalink) | |
Sponsoring Member
Quote:
{hijack off} wait... this is my own thread!
__________________
#13 (permalink) | |
What is the approximate cost for a TPS?
I get similar symptoms from time to time and checked my MAF. It's pratcally brand new (been replaced in the last 30k mi).
__________________
1998 SR5 4WD 3.4l V6 5SPD Dealer Options: 4.10:1 RR Diff Lock; Brush Guard w/ Hella driving lights [removed] Mods: Thule Roof Rack w/ Canoe Gunwhales; Silverstars; Bridgestone Revo 265/75/16s; Maglite mod; Deckplate mod; Stickers! Wishlist: TJM T-15; Custom rear bumper; 2" suspension lift; Satoshi mod; Gray-wire; Sliders; Full length skid plate; etc Quote:
#14 (permalink) |
If I remember right, I paid about $65 for mine from the dealership. That is with a discount though--not sure what normal price is. Should be less that $100.
__________________
#15 (permalink) | |
Sponsoring Member
Quote:
http://www.trademotion.com/partlocat...?siteid=214074 http://www.trademotion.com/partlocat...del=4%2Drunner
__________________
#16 (permalink) | |
Excellent, thank you.
__________________
#17 (permalink) |
Wow, I guess a 3rd gen's TPS is a lot cheaper. My bad.
__________________
#18 (permalink) | |
Sponsoring Member
Quote:
Strap22 is the Parts Dude at a Toyota dealership in Texas. He has permission to sell outside of the dealership at discount prices, so the price I quoted above (and as shown on the website) is below the normal dealer price. He shows a "$54.10 MSRP" for a TPS.
__________________
#19 (permalink) |
Just replaced mine today at $95, Its like night and day, For the life of me I cant think when it started going bad with no CEL, I just had to start clutching more and more to get the R's up and go.
(For those old enough, It was like a Carb'ed engien with no excelleratorpump) I tested it 2 mo ago and it was fine and I pulled the plug on it and got the CEL, But I figued it out and checked it again, Yup , Vcc was bad but the ECU detected IDL and VTA to E2 was ok and thought it was fine. Remember peole, Check the whole TPS for problems. |
#20 (permalink) |
Rough idle vibration on Steering wheel
I've got a 95' Toyota Tacoma 2.7 4 cyl 4X4 with a rough idling problem. I took her in to a Toyota mechanic and got soaked $118 plus. The Tech worked on it vigorously for about an 1 1/2 plus he threw in some clamps on some vacuum hoses that i was kind suspicios of. Replaced on of the pcv valves...cleaned the Throttle Body Unit...Cleaned the MAF sensor. Runs fine when moving, it's the stop at lights,when put in reverse or drive that it starts to make the Steering wheel vibrate...real annoying. Acts like she wants to stall sometimes, give her a little gas, clears right up.
I've also replaced #1 O2 sensor,new plugs,new muffler and Catalytic converter. (after market) Mechanic who installed muffler did a poor attempt at welding on pipe. Could that leak be the problem? Tech from Toyota seemed bothered that after marked Cat and Muffler that was installed. Last but not least...the longer she idles....the more she shakes! Can someone please help. I really like this truck and don't wanna upgrade to new. Thanks, Kevin |
#21 (permalink) |
midiwall - thanks for the info and the source. I remember testing mine with a friend of mine and got some weird readings. I hadn't thought about that 'till now because the engine still runs when you unplug the TPS and thought that meant it didn't really affect the performance. But, now that I've read all these posts, I think my '88 could be performing better with a new one. And that price is nice too.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Throttle Position Sensor (TPS) on '01 4Runner w/supercharger | Andrey | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-31-2006 05:00 AM |
| Throttle Position Sensor | Bassinfool | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 03-20-2005 09:22 AM |
| Throttle position sensor help | 1987 street toy | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 12-16-2004 07:12 PM |
| Throttle Position Sensor | lerence | Maintenance & Repair Archives | 6 | 08-22-2004 12:00 AM |
