will a 4-runner v6 lockrite fit 90 p/u 4x4?
like it says i have a friend with a 90 4runnner and it had a lockright or lockrite how ever you spell it that is a v6.. i have a 90 p/u 4x4 with the 22re in it.. i heard the carrier is thicker and stronger and i would need special bearing larger i.d. and the same o.d. for it to work.. i know the gears are differnt but i was curious if anyone made a kit for this to work or if it will bolt up ect.. and also what is a used on worth?? are they very streetable? or more off road? as it would be going in my dd
i read the link above.. and so i am right? it will fit with the correct bearings? if so my next questions are is this diff very streetable and whats a used one worth?
