wheel alignment HELP
just had my surf in for wheel alignment @ les schwab after i had the TG knuckle service done to it and ifs brakes installed with 1 inch spacers.
they called me soon after i dropped it off and told me that its right where it should be as far as alignment.
the problem is when im braking my steering wheel wants to veer to the left, the steering wheel isnt straight when the car is, and it looks like im a little toe in on the camber
there is no bent tie rod, the only problems i can think of is if one of the NEW brake calipers is acting up? clogged or bad brake line? an issue with knuckle shims?
should i get a second opinion????
trailgoat
08-13-2015 05:54 PM
Up&Down
08-05-2015 06:20 AM
