Sign in using an external account
| Newbie Tech Section Often asked technical questions can be asked here |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Spark Plugs
#2 (permalink) |
Personal
Sales Rating: (0)
hotter plugs for more efficient fuel burn, burn out carbon in cylinders (so i've been told. I'm still using NGKs)
#3 (permalink) |
Personal
Sales Rating: (0)
I'm really familiar with plug ratings as I raced 2strokes for a long time.
I used to have the charts between Champion and NGK memorized. NGK numbers ascend for colder plugs and Champion descend. That BP6ES is an NGK number and would be equivalent to, oh, probably an N-11Y Champion (strictly from foggy memory.) Man, I hope I got that right :-) My experience has been that NGKs are broader in heat range and more resistant to fouling than Champions. Not enough experience with any other brand to comment. Other than Bosch Platinums which are junk. I would think that with modern ignition systems, mass airflow sensors, knock detection sensors and the rest, I wouldn't be surprised to learn that tweaking the plugs' heat range doesn't get you much of anything any more. But to answer your question directly I guess I could simply state that if you drive your rig at lower rpm's say aroudn 2000 most of hte time, you can get away with running a hotter plug. If you run your rig around 5 and 6 grand you should run a "colder" plug. Just a rant from my 2-stroke motocrosser mindset. Also something else worth mentioning: I think, with unleaded gas, that the ability to "read" your plugs electrode to determine whether it is running to rich or too lean can not be accurately done. Those days ended when leaded gas went unleaded.
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- Last edited by rngrchad; 09-28-2006 at 05:52 PM. |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
If i am getting some detonation tho, wouldnt i want to try a colder plug?
#5 (permalink) |
Personal
Sales Rating: (0)
Year, Model, Engine???
If you have a 22RE you have one choice, OE style NGK or Denso... they dont run properly on anything else.
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
94 22re i have NGK's in it now, I was looking at possibly the denso iridium plugs that have a colder range
#7 (permalink) |
Personal
Sales Rating: (0)
I would stick to a stock plug, the 22RE doesnt like other plugs. I put Boschs in mine and it wouldnt even run. If your getting detonation its from something else, fix that.. dont correct something else to fix the problem.
__________________
#8 (permalink) | |
Personal
Sales Rating: (0)
this olskool method still works on carburated engines, maybe not with EFI? i still use it when i want to tweek my carbs
__________________
sarcasm noted...and appreciated im with the banned Quote:
#9 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
| Tags |
| 22re, colder, ngk, plug |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Spark Plugs Q | Rayday81 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 01-25-2009 05:53 PM |
| spark plugs | bills 99 | Newbie Tech Section | 7 | 07-18-2007 11:24 AM |
| 3.0 spark plugs | Kyle95sr5 | 86-95 Trucks & 4Runners | 12 | 01-13-2007 05:47 PM |
| Spark Plugs | alltheway | Maintenance & Repair Archives | 2 | 05-09-2004 05:13 PM |
| Spark Plugs | obxfishn | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-24-2003 09:51 AM |
