rough idle t100 3.0
Old 08-18-2015, 12:03 PM
markwink's Avatar
rough idle t100 3.0
Hi i am new to this site and already have a question. I am working on a 1993 t100 3.0 and about 3 months ago i replaced the water pump and bypass tube. A couple of days ago this truck started to have a rough idle and when in gear it feels as if the truck iss going to die. I found that the throttle position sensor was bad and replaced it but did not help. I then pinched the fuel pressure regulator line off and the truck started running smooth so i replaced the regulator and it still has a rough idle. I can still pinch off the regulator line and it runs smooth. I hhave replaced the plugs and see no signs of water and it doesnt overheat. Has anyone had this problem.
Mark
Old 08-18-2015, 12:38 PM
Turtlehead's Avatar
Check the vacuum lines and deadend caps if there are any. Also clean the MAF as the A/F ratio may be off if there is an issue with the MAFand when you pinch the fuel regulator line you are adjusting it and making it run smoother, thus I would be inclined to say it is something to do with air.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: rough idle t100 3.0
