Idle Up Valve
Old 02-26-2010, 05:03 PM
15OT30's Avatar
Idle Up Valve
just wondering what it is... i thought it was the idle speed adjuster... but i figured that out....
Old 02-26-2010, 05:04 PM
BigBluePile's Avatar
huh, looks like a blurry pic to me...
Old 02-26-2010, 05:20 PM
carguygt500's Avatar
That large black screw controls the idle-up for the power steering pump and the A/C compressor on some models. The purpose is to allow for a bump in the idle speed while the power accessories are running and placing a load on the engine at idle.
Old 02-26-2010, 06:00 PM
iamsuperbleeder's Avatar
Technically, it's called the "Idle-Up Valve", but for lame-man's terms, you can use carguygt500's definition
It works in conjunction with a vacuum valve on the power steering pump, as well as a VCV on top of the valve cover that triggers with the AC compressor clutch (if equipped with AC)
You will not find one on a truck with no power steering and no AC, as there's no need for the valve then, and there's just a plug there
Old 07-02-2015, 10:02 AM
dr1pepe101's Avatar
where can I find one to replace mine
smthwsn357
12-04-2023 02:08 AM
Blamalam
03-12-2022 07:34 AM
montanatruck
02-26-2017 07:07 AM
kyletbert
07-17-2015 11:39 AM
sojourner567
07-16-2015 08:52 PM
Quick Reply: Idle Up Valve
