Fuel Filter Replacement
Ive looked and cant seem to find instructions on fuel filter replacement on a 22RE. Can you guys point me in the right direction.....
looking at engine its on the left side between the intake manifold and the starter with a bracket bolting it to the block. I find its best to just take the starter out all together, but thats just me.
If you can't figure out how to change a fuel filter.....set the wrench down, walk away.
But seriously, get yourself an FSM. That will be the biggest help. You will need a 17mm and a 12mm for sure. 14mm for the starter bolts (assuming you remove it) and 10mm for the access panel bolts (pass side, inner fender skirt from the wheel well area)
Thanks guys....I took the access pannel off last night expecting it to be a quick job and lost interest when I saw how burried it was and was looking for some tips to make it quicker / easier. Thank you
Brian
Brian
TURBOrunnerNM
07-22-2015 11:01 AM
