building a 2" body lift
Hey guys new to the site but not to yotas. What I am trying to do is build a 2" body lift for my 86 truck and need to know if the spacers are two inches irate they taller because of removing the rubber bushing between the cab and frame?
is it really cheaper to build one compared to buying a kit? Seem like by the time you buy materials and hardware you would be near the price of a complete kit.
Not only are the kits easier but they are also cheaper and tend to be safer. I've seen many body lift "pucks" on the trail that have been cracked or torn out. If you must do it yourself then you should email Roger of 4crawler. He'll know just what you need.
Just measured. Spacers are exactly 2 inches tall.
Make them as wide as you can too.
I would still just buy the kit though.
I have some mc109 in 2" diameter that we use to make plastic gears that will work perfect just need to step the end to fit into the cups on the frame. I plan on drilling out the frame and using 7/16 bolts grade 8 the only other thing I might need to make is a steering extention.
Hey lancer what part of VA r u denwitti here. Thanks for the info rob. I have built both front and rear bumpers, grill, shift and control knobs, and have seats out of a Mazda 626. Hopefully will be installing a flatbed soon
:wabbit2:
Dinwiddie, VA?
I'm around northern Richmond
Check this page for info:
http://www.4crawler.com/4x4/ForSale/...Kit.shtml#Body
http://www.mcmaster.com/#washers/=a012v8
I would also use nylon inserted lock nuts to be sure they don't back off.
They will likely fail eventually, you might as well replace them before they do.
