86 4cyl. axle housing accepts 92 third member?
Ive read the threads, and the tech I just want to make sure Im understanding correctly.Im not going to hav any problem bolting a third member from a 92 v6 4runner to my 86 4 cyl. axle housing.Am I on the right track? Any input is appretiated
The sort of being the x factor ...as long as the 92 third member is a two pinion (non turbo) carrier right? wht about axle diameter? will this be an issue theyre both 27 spline shaft inputs
You did read what i posted, right?
79-95 the 8" thirds are identical and can be swapped into any 8" third carrying toyota axle.
doesnt matter if it's two pinion or 4 pinion, the mounting pattern and spline count are the same..
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
