2004 3400 thermostat installation problem
while replacing thermostat on 2004 toyota tacoma with 3400 engine when i removed the 3 nuts the bottom bolt the stud came out. When i replaced the stud after installing thermostat the first 2 or 3 threads pull off. Before I go any farther what should i do? any help will be appreciated.
PS By the way i am new to the site.
Galla Creek
Galla Creek
Welcome to Yotatech. Just to help you out in the future, it's generally asked that you don't start multiple identical threads in different sections here. That just clutters things up. You've gotten answers on your other one... chances are, people that are seeing one of your threads are going to see the other (I think most people use the "new posts" link... which will bring up both of your posts.) People will not post their answers on both your threads.
the1998sr5
15
07-14-2020 08:35 PM
rushw
07-18-2015 01:46 PM
Poncho0206
07-10-2015 06:21 PM
2002, 2004, 3400, 34l, camry, change, install, installation, stud, tacoma, thermastat, thermostat, toyota, tundra, v6
