Items Wanted Vehicle and non vehicle related
WTB[MidAtl]: 22re TPS harness connector
Old 12-04-2016, 02:38 PM
I8URSVT's Avatar
Looking for a 22re tps connector. The connector on my harness is cracked, so looking to replace. Will see the connector and at least a couple inches of wiring so i can splice it into my harness.
Old 12-05-2016, 10:43 PM
atcfixer's Avatar
Does your connector match the one below? Their price for their kit/wiring is extremely expensive, but I make harnesses and such for ATV's, and if that connector is correct I could most likely sell a pig tail replacement with oem color matched wiring for a fair price. Based on my research and the site below, that connector was only used on 89-95 22RE engines, the older style I can't seem to source the connector on for new.
http://www.lceperformance.com/22RE-R...-p/1063034.htm
Old 12-06-2016, 05:48 PM
I8URSVT's Avatar
Unfortunately from what ive read, the 89+ uses a slightly different shapped TPS, so it has to be from a '85-88 22re
Old 12-06-2016, 09:37 PM
atcfixer's Avatar
I see, so you do need the older gen connector. I might be able to hack one off an 86 re, but I'm not sure how soon I can do that, I'd like to get the engine sold before hand to be sure the buyer doesn't need any of the connectors off the orig harness (it's already hacked up pretty bad).
Old 12-07-2016, 03:09 AM
I8URSVT's Avatar
That would be awesome if you would be willing to cut the harness up. Would love to have it within the next 2 weeks, but i understand you not wanting to cut it up until the engine is sold. The truck is currently my daily driver, so would love to fix this asap.
Old 12-13-2016, 06:25 PM
I8URSVT's Avatar
Bump!
Old 01-04-2017, 02:58 AM
arlindsay1992's Avatar
90% sure I have one with a bit of wire on it. You could also unclip your wires from the plug and just clip them back into the new plug to avoid cutting/splicing. Let me check when I get home.
Old 01-04-2017, 04:48 PM
It has about 2 or 3 inches of wire. It's missing the little metal clip that secures it to the TPS. Rubber boot is still pliable and not torn. What's it worth to you?
https://i.imgur.com/OjiFidl.jpg
https://i.imgur.com/Gxt1HOB.jpg
Old 08-16-2017, 01:44 PM
4runnercal7's Avatar
do you still have this for sell?
Old 08-16-2017, 01:50 PM
I can't remember anymore. I can check today.
Old 04-15-2018, 03:03 PM
rous's Avatar
Could possibly post a pic of the wiring layout for that TPS connector? What color is IDL, VTA, VCC, E1? Thank You!
