Oil capacity in 4.0
Oil capacity in 4.0
I did a search and could not find capacity on the 4.0. Found it on the 3.4 several times but already knew that was 6 qts. What is it on the 4.0?
I picked up a filter last night and checked the part number. It was the same as the 3.4, but the filter I took off that was from Toyota dealership was a little longer. I put in 6 qts and it is just barely above the full line. The manual said 5.5 I think, but that is what the 99s manual said also and I always run 6 in it.
Any help?
Any help?
