Which Circuit for Dual Battery?
Old 05-10-2015, 03:47 PM
Alaska90's Avatar
Hello,
I'd like to install a 2nd battery in my 2014 Tacoma Double Cab 4WD. I'm going to use a relay to connect positive terminal of the aux battery to charging system. Ideally, I want the relay to only be energized when the ignition switch is in the RUN position. (Although I understand it might be necessary for the relay to be energized when the ignition switch is in the ACC position.)
I'm planning to use one of the "Add a Circuit" products to create a power lead for the relay.
Does anyone know which circuit, preferably located in the engine compartment fuse box would be best to piggyback to?
Thanks so much.
AK
moparbay
03-10-2023 03:50 PM
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Daenerysdad
10-01-2015 07:33 PM
runnermedic
13
09-21-2015 05:20 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: Which Circuit for Dual Battery?
