ZUK mod question - Uneven leafs
Old 04-18-2012, 04:52 AM
jetpilot's Avatar
I'm preparing to do a ZUK mod on my 87 pickup, but I've noticed that the right side of the truck sits an inch lower than the left. I'm afraid that after the mod is complete, it will still be uneven.
Will a ZUK mod fix this or should I be getting new leafs? Thanks!
Old 04-18-2012, 04:54 AM
Utah4Runner86's Avatar
New spring pack. A helper coil will reduce the unevenness, but probably won't prevent it.
I suppose you could screw around with a stiffer coil on the saggy side, but that'd be trial and error and not a clean fix.
Old 04-18-2012, 07:56 AM
JonnyBoy's Avatar
Also check to make sure it's the leaf that's sagging and not the right side torsion bar for the front. The front is alot less flexible, so it tends to make the rear flex to compensate for it.
Old 04-18-2012, 08:31 AM
cman1's Avatar
x2
Old 04-18-2012, 09:06 AM
cman1's Avatar
i have a pair of tj springs cut to "12 id sell for $15.00 plus shipping.
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
makemusic116
08-02-2015 05:23 PM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: ZUK mod question - Uneven leafs
