Would it fit?
Old 11-13-2008, 07:21 PM
kountry_boi's Avatar
Would it fit?
I have a 1993 toyota ex cab with a 4" tuff country lift.
I would like to buy a seller's weld mountain crusher 15x10 rims. He doesn't know if it's a 3.6 (22 m/m offset) or 4.6 (44 m/m offset) backspacing.
Do any of you have this set-up with the 4.6 backspacing rims?
Lift kit said not to use rims exceeding 3.75 backspacing, but my stock rims fit perfectly also I think 4.5 backing 0 offset.
Also, I know the 3.6 backing will fit because I currently have a 15x12 weld typhoons on truck.
Thanks
Old 11-13-2008, 10:44 PM
anyone???????????
Old 11-14-2008, 10:48 AM
elripster's Avatar
The rims pictured in your avatar are not stock though. Are those the ones you are thinking of? I had a trailmaster lift, and stock rims would not fit at all.
In the end, just get under your truck and measure the distance between your suspension and edge of rim. If there's room go for it.
Frank
Old 11-16-2008, 02:25 AM
so I just bought the rims, but it doesn't say what size it is. I know my 15x12 welds say it on the rims, but can't find it on these ones. It's the weld mountain crushers, but guy say it's 15x10 and I tried measuring it and it and it seems to be 12 wide.
elripster:
the rims are my old 15x12 on 31x11.5 tsl's. the stocks are the ones that look like spokes (I think there's like 6-8 spokes). I measured the backspacing one the stock and it's like 4.6 (i think) and the welds I just bought are 3.75
I have a tuff country kit
Old 11-16-2008, 01:13 PM
Jay351's Avatar
Stock backspacing is 4.75"
The rim will fit but a wide tire will not. If you are running a 10.5" wide tire you will be okay. Any wider and your treads might rub the frame.
Old 11-16-2008, 01:46 PM
yeah my stockies has 10.5'' wide tires on them so no rubbing, but since my welds I just bought are 3.6-- backspacing (supposily) it's all good. I am planning to put either my old 31x11.5 tsl's on the weld's or maybe some 33x11.5 in the near future.
Old 11-16-2008, 01:49 PM
oh do any of you know how to take out that black spots on the rims. It was storaged for a long time and has those black (asphalt type thing) on the rims. I tried hand polishing and digging my finger nails but it only helped a little.
Do you think I should buy a powerball and will it work?
87SR5justin
09-29-2015 02:50 PM
4runnerFireman
09-29-2015 06:24 AM
myotherrideisayoshi
09-29-2015 05:41 AM
mtrdrms
09-26-2015 07:12 AM
anniesball
09-05-2015 08:45 AM
Quick Reply: Would it fit?
