will w56 and g54 trans shifter handle interchange?
Old 05-24-2016, 10:41 AM
I8URSVT's Avatar
Will the w56 and g54 trans shifter handles interchange? I've currently got a g54 and I know the W series bends left and the G series bends right. My new setup needs left bend, and figured it would be easier to just swap it out rather than cut and re-weld it. I tried searching and didnt come up with anything.
I know the shifter bases themselves are different and wont swap.
appreciate the insight guys
Old 05-25-2016, 06:24 AM
dbbowen's Avatar
youll have to tweak the shifter handles and bend em a little bit so that they dont hit each other. You might run into some issues with the handles hitting your trim if you have it
Old 05-26-2016, 05:47 PM
I8URSVT's Avatar
Im going to be using triple shifters, but need the trans shifter to be on the left side like the w56 for clearance purposes.
So they should be able to interchange between shifters?
Old 05-27-2016, 11:40 AM
dbbowen's Avatar
Ah, Im not really sure then. Im sure someone here can help. Heres a bump to your thread
Old 06-03-2016, 03:59 PM
wadds's Avatar
I can't answer your question, but I do have a W56 shifter handle that is currently out, so I could take pics or measurements for comparison, if that would help.
Old 06-03-2016, 06:46 PM
I8URSVT's Avatar
I was able to try it today, and the shifter handles do interchange
