What type of tranny fluid for 86 4 Runner auto with 22RE
Old Nov 9, 2007 | 07:43 AM
dbeal's Avatar
I'm getting ready to replace the shift selenoids (spelling) on my daughters 86 4Runner with 22REengine Automatic Transmission. What is the type of transmission fluid that is required for this transmission? Dextron III, Mercron, ?? I asked at the local parts stores and no one knows for sure..I called the dealer, and naturally the parts guys said our Toyota fluid...Blech..
thanks in advance..
Darrell
Old Nov 9, 2007 | 08:26 AM
eric-the-red's Avatar
If it's an A340 series it should be Dexron II/III. Check the bottom of the dipstick, sometimes it's engraved on there.
Old Nov 11, 2007 | 07:51 AM
87turbo's Avatar
Dex/Merc or Dexron III it will say on the bottle...
Old Nov 11, 2007 | 11:12 AM
4runnerx3's Avatar
Clean the filter while you're in there.
Old Nov 11, 2007 | 02:46 PM
86tuning's Avatar
Originally Posted by 4runnerx3
Clean the filter while you're in there.[/IMG]
Actually, just get a new drainplug and gasket before draining it. $10 for both from the Dealership.
Most of the time those itty bitty 14mm drainplugs are stripped in the pan. Chasing the threads is a good idea too.
Hmmmm.... actually I've never done a trans fluid change on an 86. But the 90+ Runners use the same drainplugs as modern Corollas, and they're always messed up due to overtightening and re-using of the drain plug gasket.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
stagger_lee
Mar 29, 2016 06:27 PM
ian1386
Jul 1, 2015 11:23 AM
quaale94TRD
3.4 Swaps
Jun 23, 2015 10:27 AM
crazypaint
Jun 23, 2015 03:27 AM
