What size lift should i get - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-11-2009, 09:08 AM   #1 (permalink)
desert-rat660's Avatar
i just bought an 84 solid axle to put under my 94 pickup. I want to go with the trail gear sas kit. My question is how tall a tire will the 3" inch kit clear?
I want to be able to run 35 inch tires. i just dont want to have to cut and rotate the knuckles for pinion angle, are install a dual transfer case setup.
__________________
94 toyota pickup 22re, 4" SAS. BFG 35x12.50
08 Yamaha YZ450F
06 Yamaha YZ450F
desert-rat660 is offline
Old 01-11-2009, 03:54 PM   #2 (permalink)
SMOD's Avatar
You can always get different leaf springs and shackles to lift the front more.
I suggest Rancho RS 44044 leaf springs and downey 6 inch shackles up front and bilstien shocks 14" of travel. It should give a lift of somewhere close to 10 to 11 inches I believe.
__________________
92 Japan made 4Runner SR5 - SAS. Rear Chevy 63's. 6in. wider wheel base. 6 shooter knuckles and hysteer. 14in Bilsteins. Flowmaster. and more :)
My photo album
http://www.yotatech.com/album.php?u=42437
SMOD is offline
Old 01-11-2009, 05:44 PM   #3 (permalink)
ovrrdrive's Avatar
I think you'll find that you're going to need the 5" kit to run 35's unless you want to do some trimming. The 5" kit may still rub a little but you'll probably be able to tolerate it.
Depending on how much rubbing you can tolerate and how much you're willing to trim though the answer could be anything at all. The front of my truck has about 6" of lift on it and I also have a 3" body lift and I can still stuff my 36's into the fender. It's a little different though when you do the SAS.
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 01-11-2009, 05:57 PM   #4 (permalink)
scuba's Avatar
44-17.5 R24
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 01-11-2009, 07:43 PM   #5 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Please note that there is no 3" kit...there are 3" leaf springs which in essence with hangers and shackles will yield 4" of lift etc and so on.
I have an 85 with 4" springs and it clears 35s fine. The problem you run into with tires larger than 35s is scrubbing the firewall, thus you want to tub the firewall or break out the sawzall.
waskillywabbit is offline
Old 01-11-2009, 08:06 PM   #6 (permalink)
ya i think im goin to go with the 3" leafs, anyone know if the LCENGINEERING kit is the same as trail gears kit? LC is close by and i wouldnt have to have it shipped
__________________
08 Yamaha YZ450F
06 Yamaha YZ450F
Old 01-11-2009, 10:47 PM   #7 (permalink)
t0mwat3r's Avatar
Quote:
Lc is a dealer for trail gear according to the trail-gear website so i'd say its the same kit.
t0mwat3r is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tires Size with lift 94_yota_pickup 86-95 Trucks & 4Runners 3 05-29-2008 05:40 AM
biggest size with no lift??? camo31"10.50" Newbie Tech Section 10 10-17-2007 08:56 PM
Body lift size? Thrillbilly Offroad Tech 3 11-23-2005 06:44 AM
tire and lift size decepticon 95.5-2004 Tacomas & 96-2002 4Runners 0 05-09-2003 07:47 PM
what size lift? moclov 95.5-2004 Tacomas & 96-2002 4Runners 1 10-30-2002 07:42 PM
2009 InternetBrands, Inc.
