What size bumpstop to use with OME springs?
Old 04-21-2012, 04:53 PM
Mr. Gold444's Avatar
For whatever reason, my truck does not have any rear bumpstops. Since I'll be putting on some OME springs, I figured I should invest in some stops. Most of the stops I've looked at are meant to be welded to the u-bolt flip plate (which I don't have).
Right now the distance between the springs and the frame extension is about 6". So with the 2" lift from the springs, that height will increase.
I've been looking at these stops http://www.energysuspensionparts.com...p?prod=9.9104#
And if things permit, I'll weld them to the frame extension.
Do those seem like a good size to use?
Thanks.
nvdesertrunner
05-11-2020 08:18 PM
justdifferentials
Just Differentials
08-30-2015 08:42 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: What size bumpstop to use with OME springs?
