Weld a 4 Pinion rear diff.
Old 11-28-2009, 07:42 PM
the_ocho's Avatar
Question Weld a 4 Pinion rear diff.
so today since my truck is down for a clutch i figured id pull my third and weld my diff. well not thinking about it i pulled it out assuming i would just be able to weld it like all the pictures iv seen on here. well i have a 4 pinion diff so i dont have windows to weld trough.
So i would love any pictures or suggestions on how to do this if possible... and do i HAVE to take the ring gear off to split the two halves or can i just unbolt em and split em?
Old 11-28-2009, 07:45 PM
RMA
RMA's Avatar
man I cant help you but can you take pictures of this "4 pinion " you have . My 94 is suppose to have 4:88 4 pinion and and my 88 has 4:10 2 pinion and I dont know the difference .Ive seen the 2 pinion but not the 4 pinion.
Thanks Man !!
Old 11-28-2009, 07:47 PM
the_ocho's Avatar
my gears are 4.56 but that doesn't matter.
Old 11-28-2009, 08:11 PM
RMA
RMA's Avatar
so I see the case part in the center is different , the 2 pinion doesnt have one like that. OK thanks a good luck taking it apart man !!
Old 11-28-2009, 08:34 PM
the_ocho's Avatar
if you look in the FSM it will show you both types so you can compare them
Old 11-28-2009, 09:15 PM
the_ocho's Avatar
so lets say i split it open and run a bead where i circled all the in all four spots. good?
Old 11-29-2009, 12:05 AM
weaselman's Avatar
i didnt even take mine apart. just took the 3rd member out and welded all the spots i could reach with the gun, then rotated some more and did the same thing.. havent had a problem in over 5000 miles. (daily driving, rubicon, snow runs.)
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
HaydenConQueso
07-12-2015 05:22 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Weld a 4 Pinion rear diff.
